window problem
Old May 14, 2012 | 05:30 PM
danskool's Avatar
danskool
Go Bills !
Mine has been real lazy also. Both sides, Slows right down about midpoint to a crawl. I need to try the grease thing also.
Old May 14, 2012 | 06:57 PM
Smokiesman's Avatar
Smokiesman
On the 99 I had the goofy window would work fine for diff periods of time then just quit??? Turns out the motor armature had a dead spot on it!! If it stopped on that spot no work!!! and always when it looked like rain!!! Bought a rebuilt motor and worked like a charm!!
Smokie
Old May 15, 2012 | 07:30 AM
afinepoint's Avatar
afinepoint
Make sure the motors are good and try silicone spray in the window channels. The silicone is not as messy as grease, quicker and easier to apply.
Reg
Old May 15, 2012 | 05:22 PM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
Grease collects dust and grit. Not good things to have in your window track. I use and recommend spray graphite. Buy it in a spray can, it sprays on like WD-40 and the carrier then evaporates leaving dry graphite lubricant. It works great, last a long time and it does not collect crap that will compound the problem.
ebmvw1004
Apr 8, 2018 07:11 PM
ErrorS
1978 - 1996 Big Bronco
Dec 19, 2011 01:32 PM
Joker50
Jun 12, 2011 12:13 AM
Highmark18
Apr 4, 2007 06:24 PM
Mudder
Mar 23, 2005 04:21 PM
