serpitine belt
Old May 14, 2012 | 08:41 AM
RobertJohn's Avatar
RobertJohn
serpitine belt
This may be a dumb question !
When you put a new belt on must it line up exactly in all the places where the inside part runs ? Or will it fray from not being lined up properly ?
Old May 14, 2012 | 09:06 AM
mtdigger's Avatar
mtdigger
Iirc...as long as you install it properly by the diagram...once it turns a few loops it'll center itself, hopefully someone can confirm this...or dispute it.
Old May 14, 2012 | 09:41 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Correct. You can turn it over by hand to center it too
Old May 14, 2012 | 10:14 AM
RobertJohn's Avatar
RobertJohn
follow up
the reason for my question is this .. sat. i put my new power steering pump on and put the current belt on.
After a few minutes of driving and idling i noticed some fraying.
in checking i found the belt was not centered on the crank shaft and rubbing on the inside.. I moved the belt to center of the crank shaft and so far no more fraying.
But I do need to replace this belt due to the fraying issue and will keep it as a spare in case of emergency.
Old May 14, 2012 | 11:13 AM
smithrock's Avatar
smithrock
Yes, replace it. Keep as a spare
Old May 15, 2012 | 05:29 PM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
You have to start with it centered on the grooved pulleys (the smooth ones don't matter) because it will not move out of the groove it starts in once you release the tensioner unless you move it. So no, it does not self center.
Tony2847
Escape & Escape Hybrid
Sep 10, 2018 01:14 PM
vanman23
Jul 15, 2014 12:54 AM
lio45
Dec 1, 2010 07:33 PM
4wydnr
Dec 30, 2008 05:27 PM
pipesalesman
Feb 6, 2007 01:28 PM
