Door panel Bulge
Old Apr 7, 2018 | 12:42 PM
ebmvw1004's Avatar
ebmvw1004
Door panel Bulge
Hi new member here. I have found a lot of great advice and knowledge this far which lead me to becoming a member. I have a 1993 f250 xlt and when I roll my driver side window all the way up the door bulges out quite a bit. It did this with the previous window regulator and in trying to figure out the problem I burnt it out. I bought a dorman replacement 741-674 and it seems to be worse. Anybody ever come across this? Or find a fix? Passenger side does it as well and I havnt touched that side. My driver side is all taken apart all new parts to put it back togethar and I want to do it right the first time. Thanks
Old Apr 7, 2018 | 09:34 PM
Ddaybc's Avatar
Ddaybc
My 1994 with electric windows did this too. I simply didn't wind the window up as tight as it would go. However, it is not supposed to do that. There is supposed to be some kind of stop designed into the system to prevent the window from being raised too high. When it does happen the mechanism twists and puts pressure on the door panel causing the bulge. I never looked into it but I think there is supposed to be a tab on the window mechanism to prevent it from going up too high. I don't know if it is located on the window crank gear or on the mechanism attached to the window slide. Look for bright shiny spots on metal that look like they should stick out and get in the way???
Sorry, not sure how to word this. I hope this gives you something to look for that will allow you to track down the issue.
Old Apr 7, 2018 | 09:59 PM
ebmvw1004's Avatar
ebmvw1004
That sounds about right. I think you're right on point. Now just a matter of figuring out how and where I'm going to add a tab. Gonna have to play with it to check it out.
Old Apr 8, 2018 | 01:44 AM
Cummings Guy's Avatar
Cummings Guy
Not sure what you mean by quite a bit or door bulge. It is normal for the inner door panel to move when the window stops moving and the motor stalls. Electric motors produce maximum power at zero RPM.
There is no tab to stop the window at the top of travel. It just nests in the top of the rail.
Unless the regulators mounting points are cracked or broken, there is nothing to worry about.
Old Apr 8, 2018 | 10:46 AM
ebmvw1004's Avatar
ebmvw1004
So when the window reaches the top and nests inside the channel a little bulge out or flex from the door panel is ok? I've talked to a few other guys locally who own different makes and models and the general concescus is that "it's just that way." So I moved on. Next thing. That new dorman regulator is wired backwards. Now on my power window switch up is down and down is up.
Old Apr 8, 2018 | 11:26 AM
Cummings Guy
Yup.........
Old Apr 8, 2018 | 12:37 PM
Ddaybc's Avatar
Ddaybc
Everyone may be right about the bulge in the door panel when the window goes all the way up. However, my 92 doesn't do it. Maybe it's the "different" one. At any rate, I had the truck from 2011 to 2017 and it was not a concern of mine so you should be OK.
Old Apr 8, 2018 | 04:46 PM
My4Fordtrucks's Avatar
My4Fordtrucks
easy fix to swap the wires in the connector. The side marker lights for my Jeep were backwards. Aftermarket junk.
Old Apr 8, 2018 | 07:11 PM
Diesel_Brad's Avatar
Diesel_Brad
Agreed 100%
Trent Racer
Aug 26, 2021 08:27 PM
Roger T. Pipe
Jul 7, 2019 06:43 PM
Nick bass
Jan 27, 2013 11:54 PM
ghanson
2004 - 2008 F150
Mar 3, 2012 01:56 PM
68GTCS
Nov 10, 2004 10:03 AM
