Pinion play
Old May 9, 2012 | 11:15 PM
Tomahawk2506's Avatar
Tomahawk2506
Pinion play
My 67 F250 has a dana 60 rear. I removed the pinion yoke to change the pinion seal. The pinion has about 3/16" play forward (toward diff cover) and back. Side to side feels ok. Is this too much play? Time for a rebuild?
Old May 9, 2012 | 11:26 PM
jacks61ford's Avatar
jacks61ford
without the pinion flange there won't be any tension on the bearings causing play the pinion nut properly torqued down should remove all the play
Hooked Too
Oct 15, 2017 11:20 AM
aidandj
30
Nov 9, 2015 03:14 PM
lafermedavid
May 13, 2012 10:53 AM
xlt4wd90
Dec 13, 2010 04:13 PM
kopfenjager
Mar 2, 2005 12:42 AM
