pinion yoke
Old May 12, 2012 | 12:35 PM
lafermedavid's Avatar
lafermedavid
pinion yoke
Hi.I just finished swaping this dana 60 under my 75HB.I now notice I have quite a bit of play in my pinion yolk.What could be the culprit besides a loose pinion nut.I ordered a 1350 yolk and seal,which I was replacing anyway,before dealing with the driveshaft,any suggestions? thanks in advance
Old May 12, 2012 | 02:27 PM
f5fordgirl's Avatar
f5fordgirl
Is the yoke loose on the pinion shaft, or are you getting play between the pinion and ring gear?
Old May 13, 2012 | 10:53 AM
lafermedavid
pinion yoke
Hi Thanks for responding,the yoke is loose at the pinion shaft,the ring and pinion seem solid,their is about an 1/8" of play ,the old dana 44 I took out has no play.
burnthelight88
Nov 18, 2020 06:46 PM
Tomahawk2506
May 9, 2012 11:26 PM
kopfenjager
Mar 2, 2005 12:42 AM
thielemonster
Mar 26, 2002 03:48 PM
