trans. issues
Old May 9, 2012 | 11:43 AM
SHO rescue 79's Avatar
SHO rescue 79
trans. issues
I have a 88 350 with a n/a 7.3 and a c6. The trans. dosn't go in reverse all the way, It will start to move slowly then it will bang into gear. It also wants to hold 2nd gear to long even with casual driving it dosn't shift into 3rd untill 3,400 rpm. It dosn't do either all the time it's hit or miss.
Old May 10, 2012 | 02:52 AM
Aune163rd's Avatar
Aune163rd
Sounds like a c6 with its pump on the way out...OR its the VRV....
Old May 10, 2012 | 09:20 PM
SHO rescue 79
If it's the pump should I do a rebuild? Also what is the vrv?
Old May 15, 2012 | 11:33 AM
eatont9999's Avatar
eatont9999
The Vacuum Regulator Valve is attached to the injector pump and uses vacuum to tell the transmission where the IP lever is IE: throttle position. If it goes bad, it may not send the correct vacuum pressure/suction to the trans and it won't know when to shift. The reverse issue is unrelated to the VRV, though.
big ole ford
Aug 24, 2017 06:27 PM
racinmike88
Oct 18, 2010 10:55 PM
562dragnhra
Oct 14, 2009 02:19 AM
bill-w
Apr 18, 2009 10:19 PM
edwardldog
Jan 3, 2005 10:51 AM
