Trans limp mode
Old May 13, 2012 | 05:10 PM
deano-was-his-name-o's Avatar
Trans limp mode
I drove my truck about 2 hours die the hill we call it. I parked it for 2 hours. Got in it the over drive light was flashing and the Trans was in limp mode. I turned the truck on and off twice nothing happened. I pulled off the battery cable for 15 min and it reset itself. 2 years ago I replaced the sensor up by the oil fill with the 2 wires by it , because the Trans did the same thing and the wires were frayed. I remember there was a sensor that measured altitude? Any help would be great. Thanks
Old May 13, 2012 | 06:49 PM
'94IDITurbo7.3's Avatar
'94IDITurbo7.3
first things first. scan it for codes.
that is the baro sensor that measures altitude.
'94IDITurbo7.3
double post
Old May 14, 2012 | 08:53 AM
You think there will be codes when I unhooked the battery? I will check a history. It will be Tuesday before I can take it in
Old May 14, 2012 | 09:13 AM
'94IDITurbo7.3
has the light came back on since you unhooked the bats? if the light has not come back there might not be codes but i am not positive.
Old May 14, 2012 | 10:06 AM
No light since. drove it home and some place else total of 3 hours. Ruins great. The trip was a drop in elevation. About 2,500 elevation drop. That's why I was wondering about the baro sensor
Old May 15, 2012 | 01:18 PM
Ok.... No codes now or in history......
Old May 15, 2012 | 01:19 PM
What are the 3 that can cause limp mode? As far as I know there is no other symptoms
Dave Bitton
1997 - 2003 F150
May 24, 2017 09:07 AM
ajorn
Feb 9, 2010 08:20 AM
djmicko
Feb 21, 2009 07:47 PM
IceboxFX
27
Mar 24, 2008 04:50 PM
deanj
Nov 23, 2005 04:05 PM
