Flywheel replacement difficulty
Old May 9, 2012 | 08:54 AM
zhoeffner's Avatar
zhoeffner
Hi all!
I am looking at purchasing a 1983 F350 with the 6.9 IDI diesel motor and 4 speed manual transmission. The seller states that the flywheel is missing 1+ teeth and thus has some difficulty starting. My question is- How hard is it to replace the flywheel? Is it a job you can do in a few hours in the backyard, or is it something that would be better taken to a professional?
Thanks for your time,
zhoeffner
Old May 9, 2012 | 09:24 AM
Rogue_Wulff's Avatar
Rogue_Wulff
Most manual trans flywheels have a replacable starter ring gear. If the flywheel is in good condition, that would be a far less expensive route to take.
Dropping the trans to access the clutch/flywheel is not that difficult, but it helps if you have a transmission jack.
Since you'll be taking the clutch off anyways, this would be a great time to replace it if it isn't in very good condition.
Artf0rm
Oct 28, 2013 11:23 PM
outsource77
Jul 2, 2009 02:29 PM
paulbunyan22041
Apr 9, 2004 07:03 AM
unclecrusty
Mar 3, 2004 07:34 PM
lee
Apr 30, 2002 02:22 AM
