4 speed trans 4x4
Old May 8, 2012 | 05:42 PM
james64's Avatar
james64
4 speed trans 4x4
Will the transfer case from a 77 4 speed fit onto a 75 C6 transmission? Both transmissions are from 1/2 ton trucks.
Old May 9, 2012 | 11:48 AM
james64's Avatar
james64
Any body know?
Old May 9, 2012 | 12:27 PM
HIO Silver's Avatar
HIO Silver
Help us out. We're not clairvoyant. NP203 or 205? Married or remote?
Read and deduce:
Offroad Design - Fullsize 4x4 Performance
Ford C6 to np203 adapter with shifter and mount - Pirate4x4.Com
Ford np205 adapter questions [Archive] - FSB Forums
Looks like an adapter is required when it's a C-6 to an NP203.
Transfercase
Old May 9, 2012 | 12:29 PM
Stinky7-11's Avatar
Stinky7-11
I don't think it will, i'm assuming your speaking of a married setup. You will need the correct trans to t-case adapter and the matching C-6 output shaft if it's a conversion. Is it a np203 or np205?
Just thinking if your just looking to replace a bad t-case it should bolt right in providing it's the same model case, if your switching a np203 for a np205 you will run into driveshaft lenght issues for the front but rear may fit
Old May 9, 2012 | 01:02 PM
james64's Avatar
james64
I believe its a 205 the transfer case is married to the 4 speed. I was looking to change the transfer case over to the c 6 auto transmission. The transfer case does have 4 high 4 low and 2 high.
Old May 9, 2012 | 01:10 PM
HIO Silver's Avatar
HIO Silver
Sounds like a 205. In any case, use Offroad Design's link above to verify.
Old May 9, 2012 | 01:16 PM
Stinky7-11's Avatar
Stinky7-11
Originally Posted by james64
Not sure if it is a 203 or a 205 the transfer case is on the married to the 4 speed. I was looking to change the transfer case over to the c 6 auto transmission. The transfer case does have 4 high 4 low and 2 high.
HIO sent you links with photos, first thing you need to do is figure out what you have! that shift pattern should be a np205, if all your doing is a swap and they are both np205's you should be fine 75-77 should be the same.
Old May 9, 2012 | 01:57 PM
HIO Silver's Avatar
HIO Silver
Sometimes I feel like I'm wasting my time trying to help out some people. Don't peeps research anymore? Or is this the day and age of instantly having the answer when you want it without doing some homework?
- Rant OVER-
Old May 9, 2012 | 02:10 PM
Stinky7-11's Avatar
Stinky7-11
- Rant OVER-
You got it dead on with thatbut we still try
dig'umz
Feb 18, 2013 10:50 PM
79str8six
Mar 2, 2012 07:01 PM
Bender99
Apr 5, 2009 07:07 PM
77460f150
Apr 22, 2004 05:20 PM
tetraruby
May 31, 2002 09:56 AM
