highboy driveshaft
Old Mar 2, 2012 | 03:01 PM
79str8six's Avatar
79str8six
highboy driveshaft
i would like to know if the immediate driveshaft(the one that goes from trans to transfer case)... is the same in a 4-speed and the c-6 with the bolt on yolk. In short..wil the 4-speed driveshaft work if i want to put in the auto c6?
Old Mar 2, 2012 | 03:08 PM
USArmyTaterness's Avatar
USArmyTaterness
I am not entirely sure as long as the spline count is the same the yolks would not be a problem but what you are than likely to run into is the drveshaft length is most likely going to be different.
Old Mar 2, 2012 | 04:06 PM
79str8six's Avatar
79str8six
with the 4 speed driveshaft it is only 24 inches or so pushed all the way in... i just cant see that drivshaft getting any shorter
Old Mar 2, 2012 | 06:22 PM
msperlazza's Avatar
msperlazza
A c6 is longer than the 4 speed isn't it? That would make the driveshaft length shorter?
In other words I'm not sure but i believe a C6 is longer thank the 4 speed trans.
Old Mar 2, 2012 | 07:01 PM
montana_highboy's Avatar
montana_highboy
The shafts are different lengths, by approx. 3", the np435 shaft is roughly 25" and the c6 shaft roughly 22".
roadrash63
Mar 21, 2013 12:48 PM
GreatNorthWoods
May 5, 2011 08:01 PM
79f100six
Nov 11, 2007 09:22 PM
lastchance
Jul 1, 2004 01:13 AM
