T-Case
Old Feb 12, 2009 | 05:37 AM
Bender99's Avatar
Bender99
T-Case
I have a 205 transfer case.... This T case came from a 460 with a C6, and while I save to build my 460 i was wondering if I can put it behind my 302 and mazda 5 speed(Have a ZF too so dont worry) so that I can have the right drive shafts made. they use differnt u-joint right? I have a sas hp d44 in truck in sig. I remember reading that any ford t case will bolt to ford trans, this right? I also want to twin stick it before putting it in. Are any transmissions longer that I can get a front driveshaft from so I dont have to have one made for the front because i have 8 inches up there?
Old Feb 12, 2009 | 11:00 AM
75F350's Avatar
75F350
You can bolt it up, but you will have to modify the adapter a little.
If you have a ZF trans dont waste you time on the M5 junk. Build it once and build it right. The M5 is just not very strong, nor is it very reliable.
Here is where you will have to modify the adapter. This is a 205 attached to a ZF5:
Old Apr 5, 2009 | 05:51 PM
kickingber's Avatar
kickingber
I thought that a transfer behind a automatic, was different than a transfer behind a manual. Am I wrong? Can you take a np205 (married) from behind a automatic(like say a c-6) and bolt it up behind a manual (like a np435) with out any mods?
Old Apr 5, 2009 | 07:07 PM
Ford_Six's Avatar
Ford_Six
I swapped my old NP for a C6 with no mods to the transfer case at all. Same splines and all. There is a bit of a difference in the linkage, but you can work around it.
BartKnox
1978 - 1996 Big Bronco
Nov 20, 2014 07:48 AM
BartKnox
Nov 17, 2014 09:52 AM
460
Offroad & 4x4
May 14, 2012 06:17 PM
Junkyardslug
Offroad & 4x4
Sep 5, 2000 01:06 PM
