Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
OBD not working
Old May 8, 2012 | 03:58 PM
hillpeople's Avatar
hillpeople
OBD not working
My F450 - V10 OBD does not appear to be working. I have located and checked the fuse (#26) Reader works on other vehicles any suggestions
Old May 14, 2012 | 11:03 AM
critterf1's Avatar
critterf1
What year? Have you checked the wiring from OBD connector to PCM?
Old May 14, 2012 | 11:48 AM
hillpeople's Avatar
hillpeople
The truck is a 2004 class B+ motor home
Old May 14, 2012 | 02:25 PM
critterf1's Avatar
critterf1
Fuse #26 should be for the airbags. Fuse #12 should be the one you need to check.
Old May 14, 2012 | 03:21 PM
hillpeople's Avatar
hillpeople
Thanks, sorry for the rookie mistake E-450 not F and the Owners guide says fuse 26
Old May 14, 2012 | 06:57 PM
critterf1's Avatar
critterf1
Whichever fuse works the cigar lighter also works the OBDII.
Old Jun 21, 2012 | 02:57 PM
190 jerry's Avatar
190 jerry
did you ever get your obd2 working?...I have an e450, '05, v10 and my obd2 won't link....power is on, etc, etc,...also won't link on my '06 e150. this seems to be a very common problem, but I have not found a fix, but still searching....J...
Old Jun 21, 2012 | 11:22 PM
hillpeople's Avatar
hillpeople
OBD
I located a second fuse under the dash, I had been looking at the fuse box under the hood. If your cig. lighter is working and the OBD didn't work in your 150 and its lighter is working then I would say the OBD is faulty. thanks John
6Fords
Jun 30, 2014 08:09 PM
CharlieA1
Modular V10 (6.8l)
Aug 25, 2013 12:53 PM
High_HP
Apr 6, 2011 01:55 PM
ntputter17
Mar 14, 2009 10:56 PM
mmmPowerStroke
Jan 4, 2006 07:14 PM
