ignition problem
Old May 3, 2003 | 09:40 AM
jwspilot's Avatar
jwspilot
ignition problem
replaced the valve cover gasket and pulled the fuel line, and a connector block attached to back of the head. (300 cid straight six, 1986 f-150). Replaced everything (I think) Now there's no spark. (pulled #1 with plug attached) Any ideas???
JWS
Old May 3, 2003 | 04:43 PM
Karic's Avatar
Karic
ignition problem
Coil wire?
Rick
Old May 3, 2003 | 05:52 PM
OldThumper's Avatar
OldThumper
ignition problem
Considering that you talked about other stuff and the title is about ignition ....Maybe you knocked a wire off somewhere.
Old May 4, 2003 | 06:31 AM
jwspilot's Avatar
jwspilot
ignition problem
In response:
The bracket in rear as well as the fuel line needed to be pulled to get the rocker cover off. Anyone know a common problem in pulling the three connectors at the (vacuum)block attached to the cover that would result in ignition failure. Is there a wire, fuse block or something else that might go???
Old May 4, 2003 | 06:16 PM
steve83's Avatar
steve83
ignition problem
The 3 vacuum solenoids have a red wire that comes STRAIGHT off the EEC Power relay, so if you had the key on AND you shorted that wire to ground, or pinched it when you reinstalled the bracket, you'd have blown the fuse/fusible link for the EEC, which also powers the ignition module.
jmcanally
Nov 10, 2016 06:09 AM
jofes
Nov 5, 2016 09:26 PM
DieselCamper
19
Jul 6, 2016 02:05 PM
ZooDad
Mar 27, 2016 10:09 AM
80351
Kansas Chapter
Jun 7, 2010 03:13 PM
