pressure in upper rad hose
Old May 5, 2012 | 12:25 PM
Greg5OH's Avatar
Greg5OH
Hey guys, just recently did waterpump, new 3core alum rad and new hoses and new 13lb cap. Truk is a 91 7.3 n/a
after a bit of driving i notice my rad is very! Hot to the touch (i assume around 190f or so), stock ****ty gauge reads ok and truck drives fine, but the upper rad hose is very firm even after shutdown untill the truck cools down. Is this normal? Or is there still an air bubble somewhere? i only had the mech fan fully lick on once when i was doing in town driving for 5 hours with a fully unlocked converter.
Old May 5, 2012 | 12:44 PM
whiteboyslo's Avatar
whiteboyslo
Sounds right to me. Top hose should stay hot and firm after the t-stat opens, and it can take a while after you shut the truck down for it to come back to ambient.
Mike
Old May 5, 2012 | 04:46 PM
IDIDieselJohn's Avatar
IDIDieselJohn
I got a question to, instead of starting a thread for it, it's basicly the same as this.
My upper rad hose, sucks it's self in when revving the engine..... but feels firm and normal cold/engine off.
Whats the deal with that? Tired rad hose?
Old May 5, 2012 | 05:07 PM
'94IDITurbo7.3's Avatar
'94IDITurbo7.3
OP- you have nothing to worry about. that is normal.
John- pretty sure the only way for that to happen would be water pump spinning in wrong direction. do you have the belt on the correct way?
NMB2's Avatar
NMB2
This is an easy one.
You need a new radiator cap. Yours is not allowing coolant back in from the overflow bottle causing a vacuum in the radiator therefore collapsing the hose.
Old May 5, 2012 | 05:09 PM
IDIDieselJohn
Thanks! I'll get a new one for it. Wouldn't hurt anyways, the one there looks original.
Old May 5, 2012 | 08:56 PM
NMB2's Avatar
NMB2
check the overflow tank hose for any obstruction as well.
Old May 6, 2012 | 12:39 PM
IDIDieselJohn
I guess the bad rad cap would also explain the missing gallon of coolant in the rad when I bought this van. Doesn't have any coolant leaks, so with a rad cap not holding pressure, it was just boiling out of the system.
Scoob5555
Apr 13, 2019 12:43 PM
abyars111
Oct 30, 2013 11:58 AM
eallanboggs
1997 - 2003 F150
Feb 21, 2009 05:42 PM
Aerocook
Aerostar
Jul 24, 2007 10:37 AM
Copper93
1978 - 1996 Big Bronco
Aug 6, 2003 06:21 PM
