XRF Ball Joints- Testing
Old Nov 14, 2018 | 07:39 PM
  #106
sand_fiend's Avatar
sand_fiend
double post
Old Nov 14, 2018 | 07:47 PM
  #107
sand_fiend's Avatar
sand_fiend
I have about 120K on them now. they are still tight.
Now the steering box is gone. you can only adjust it so many times
Old Nov 14, 2018 | 11:29 PM
  #108
duck fan's Avatar
duck fan
Because racetruck
Originally Posted by carl2591
you have 295K miles on the ball joints.. or is that mileage on truck?? confused.
If you look back through the thread you'll see that he put them on at 214,349. 80K+ so far. FWIW, XRF are the only ball joints I install on these trucks at my shop, I have had to replace one so far but it was not XRFs fault, The U-joint in the front axle exploded and pushed the upper ball joint out a bit and ruined the underside of it.
Old Nov 16, 2018 | 01:00 PM
  #109
brian42's Avatar
brian42
Veteran: Navy
Had mine on for a few years so far and am very happy.
Old Jan 27, 2020 | 08:20 PM
  #110
dougbrown's Avatar
dougbrown
Hi Guys. I’m looking to get xrf ball joints for my father 2000 F250 7.3 and my 2011 6.7 needs them. Any update?
Thanks Doug
Old Jan 28, 2020 | 11:25 AM
  #111
FordTruckNoob's Avatar
FordTruckNoob
I've only had mine since April 2019 but they're still going strong. This is with 37" tires too.
Old Jan 28, 2020 | 11:27 AM
  #112
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
My ball joints are shot and XRF is going to be my brand of choice when I get around to it...
Old Jan 28, 2020 | 12:19 PM
  #113
Bonanza35's Avatar
Bonanza35
Have had mine on for a few years now and they are great so far. 1999 cc lb 4x4 7.3 .
Old Jan 28, 2020 | 12:29 PM
  #114
brian42's Avatar
brian42
Veteran: Navy
My XRFs were great and at 70K+ miles and counting when the truck was totaled. I know it went to auction and was sold as a salvage so they're still going strong for someone else now.
  #115
Brian Hanks's Avatar
Brian Hanks
Mine don’t have that many miles on them yet but I replaced them about a year ago. I Had replaced everything steering wise including steering box and even though my ball joints tested correctly by standard methods I found they were dry and causing issues. My truck has driven like new since. Love them so far.
Old Jan 28, 2020 | 03:17 PM
  #116
SkySkiJason's Avatar
SkySkiJason
I’m installing another set this week. 2wd dually this time.
I’ve put a bunch of these in now. I have seen one failure. It was sent back to XRF for analysis - have not heard back yet.
We recently used XRF Steering parts and sway bar links. Curious how that is going to hold up.
Old Jul 24, 2021 | 05:10 AM
  #117
JJF20's Avatar
JJF20
Hey guys, Reviving this thread..
Im usually over in the OBS Section, came across this thread in a Google search..
Rebuilding my D50, looking into ball joints and steering linkage. I haven’t had a problem with OEM in the past, or Moog, on a couple of super duties I used to own. But I haven’t read much good on Moog the past few years. Looks like a big price difference on XRF vs Dana. I know one of my joints I had replaced several years ago, aftermarket at a shop, and probably the knurled / spline type, so I’m not even sure if I can use a Dana anymore on that side.
Just Dana ball joints in my hands are almost $600!
A whole kit of XRF, ball joints and all steering linkage, including sleeves is $570 from tire club. That’s in my hands, shipping, tax, exchange etc etc. In Canada. Not bad for everything in one box.
Looks like the XRF ball joints from everything I’ve read are holding up well, how about the steering parts? Everyone still happy with XRF overall?
Thanks
Old Jul 24, 2021 | 05:44 AM
  #118
FordTruckNoob
My steering linkage is still good after about 10k miles. It was installed Feb 2020.
I had a DS lower ball joint fail after 20.5k. It was replaced under warranty. Original set installed April 2019. Warranty set installed April 2021.
Old Jul 24, 2021 | 05:53 AM
  #119
Walleye Hunter's Avatar
Walleye Hunter
I got one tie rod end with now mileage on it so it's still going fine to the best of my knowledge.
Old Jul 24, 2021 | 08:46 AM
  #120
SkySkiJason
One XRF ball joint failure out of all the ones I’ve installed. It had about 30k miles on it and was replaced under warranty. No tie rod end failures yet. I will continue using these for now!
