XRF Ball Joints- Testing
Old Nov 21, 2017 | 05:11 PM
  #91
carl2591's Avatar
carl2591
the shop is literally 5 min from my house.. It takes longer to go to autozone to pickup the tool and take it back. If they come on wed and the shop is open on fri after thanksgiving I will drop it off and pick up on way home. If the shop is closed for the thanksgiving weekend I will pick up tool and and do my self..
happy thanksgivings to all
It will take longer to go to the shop, drop off knuckles, return to shop and pick them up than it will to press these out yourself. You don't need a vise - or even a workbench. I wouldn't want to do it without an impact wrench though...
Yours aren't even crusty. Those things will push right out of there. I'd say 30mins for all (4) because its your first time. Figuring out the right parts to use is the hardest part. There are a lot more parts in the kit that you don't use than parts you do use.
Old Nov 21, 2017 | 05:14 PM
  #92
carl2591's Avatar
carl2591
had a good day grossing $1,667.00 wish I couild do that very day . was a long for sure.. 80 buck is doable for sure.. NO dvr for me.. live aka TV or nothing.. commercials are time to pee... happy thanksgiving.
Originally Posted by F350-6
I guess I'm just spoiled. A couple of years ago I upgraded my satellite and got one with a DVR. Don't think I've watched an entire football game live since. Set it to record and don't start watching until it's at least half way over. Skip all the commercials and just enjoy the game.
And if you took that approach, you'd have just enough time to either do it yourself, or drive down, drop off the parts, and then drive back home to watch the game.
But it is the holiday season, and there are plenty of things to do. And I can think of worse things to blow $80 on. Plus I don't know what the weather is like there or your working conditions. Enjoy your long weekend whichever route you choose.
I think I might get to swap a turbo on the nieces 6.0, but it should be in the 70's here and I've got a nice workshop to play in, plus a DVR for any football games that might come on.
Old Nov 22, 2017 | 01:14 PM
  #93
andym's Avatar
andym
You pee every 15 minutes? Maybe you ought to slow down on the beer!
Old Nov 22, 2017 | 05:03 PM
  #94
carl2591's Avatar
carl2591
OK OK OK.. I am requesting my Man Card back.. So i was going to take the knuckles to shop, got the ball joints today in mail and decided to check out auto zone and see if they had a ball joint tool I would get.
Traffic was a fricken beach so it took longer. I asked for the tool and he brought one that had only like 5 parts. I said do you have one for 4x4 and he when back and brought this one.
I took it home and got busy and got all four changed out in like 1.5 hrs.
The lower joints were a bear and i had to pound on them with hammer along the way.
One thing I did notice is the lower joint seem to be a bit longer as the snap ring was a bit below the opening.
ALso i had to switch the grease zirks as the upper one was packaged with 90 deg one which would not work so I put the straight one in upper and 90 in lower one.
here are some photos so enjoy.
Old Nov 24, 2017 | 09:04 AM
  #95
SkySkiJason's Avatar
SkySkiJason
Man card reinstated. Good job!!!!
Not sure about that lower ball joint sticking down like that... I haven't seen that before.
Old Nov 24, 2017 | 09:20 AM
  #96
carl2591's Avatar
carl2591
me too.. i just pressed them in to the shoulder and made sure to clean it out real well and took some emery cloth to interior to clean it up so i am guess they, ball joints are a bit longer than oem. did not measure them before pressing in..
was hoping to get it put back this weekend but man it cold start to this fri morning and we have people coming at noon for thanksgiving 2.0, then work sat morn with football game in afternoon NCSU VS UNC the final game for both local rival teams so this is a BIG deal for sure.. so have to see how sunday looks for competition of project.
Old Nov 25, 2017 | 04:47 PM
  #97
SRBF150's Avatar
SRBF150
Timely thread updates! My Spicer ball joints are shot after 30K miles. I've been hearing and feeling this rattling through the floorboards for a little while and suspected the Ball Joints are bad but didn't want to think so with such little mileage since when I replaced them. Jacked up a tire, pried up on the wheel/tire assembly leveraging a 2X4 on the ground and my big prybar up on the tire, and there it was. Up/down and side play especially on the DR side. Warranty requires I send the joints in and then if determined premature failure, they would be replaced. This doesn't work for me as the truck can't be down that long. So, I just ordered a set of XRF joints from American Undercar. I changed the joints 12/27/14 per my records and it looks like it will be very close to 3 years and 30k although probably more like 25k miles... Ugh.
I sure hope the XRF's are better!
Old Nov 28, 2017 | 07:21 PM
  #98
SRBF150's Avatar
SRBF150
XRF Joint are ordered as is an OTC press and Astro Dodge/Ford 4wd adapter kit. Last time I rented the tool, it was a bit of a cluster and if I end up needing to do this job every couple years, well, I want my own tools to do it. Good to help friends too.
I'll post a video of the play in my 30,000 mile worn out Spicer ball joints soon. Have a camping trip this weekend so wish me luch towing the 5th wheel!
Old Nov 28, 2017 | 08:32 PM
  #99
liquidlounge's Avatar
liquidlounge
Dynatrac. Yes, more money, but they really are do it once for life product. To me, I thought ball joints were a big job. 30k is like maintenance!
Old Dec 5, 2017 | 11:21 AM
  #100
csnow's Avatar
csnow
Went to install the Dynatracs and grooved joints were installed previously. I am screwed, so I guess I will have to go with another grooved joint like XRF. Ughhhh.....
Old Dec 9, 2017 | 12:42 PM
  #101
Snowy21's Avatar
Snowy21
That's disappointing that the Spicers only lasted 30k. Less than a year ago I put a set in my truck to fix a sticky set that was in it when I bought it. Guess we'll see how it goes...
Old Dec 9, 2017 | 04:24 PM
  #102
SRBF150's Avatar
SRBF150
I think they were starting to go at 20k and have been loose for 5k... Yeah, I'm very disappointed.
I'm equally disappointed in Spicer's warranty process. It entails removing them and sending them in for Spicer to decide if they'll warranty them. F that S. I'll never buy Spicer again nor Moog.... I really hope XRF work. They're sitting on the bench along with my new tools waiting.
Old Nov 14, 2018 | 05:41 PM
  #103
WA.Ranger's Avatar
WA.Ranger
Originally Posted by andym
@WA.Ranger How are those ball joints holding up?
They are holding up good so far! 295,297 miles.
Old Nov 14, 2018 | 06:02 PM
  #104
carl2591's Avatar
carl2591
you have 295K miles on the ball joints.. or is that mileage on truck?? confused.
Old Nov 14, 2018 | 06:44 PM
  #105
SRBF150's Avatar
SRBF150
My XRF are doing well so far, granted, only 10k miles but that's about half way to where the spicers lasted!
