need help
Old May 2, 2012 | 12:49 AM
Russell ONeill's Avatar
Russell ONeill
need help
Hey guys im having huge problems with my 1996 f350. it ran amazing the first 9 months i had it and now it is having issues. first it would cut out every now an then then eventually die and not start back up. let it sit for couple minutes to hours and it would start up with no problem. i replaced the cam pos sensor hoping starting small would work. it now starts and idles fine and doesnt die but when i get on it a little or get up to around 1700 rpm to 1900 rpm it cuts out an i slow down. i also replaced the fuel filter. i have to drive it to work every day slowly but it always starts and goes until i get the rpms up. thanks
Old May 2, 2012 | 12:50 AM
mojoman's Avatar
mojoman
check your fuel pressure...sounds like your pump is fading...
Old May 2, 2012 | 12:58 AM
Russell ONeill
ill check that in the morning. thank you. still would like other sujestions also
Old May 2, 2012 | 07:16 AM
Talyn's Avatar
Talyn
Fuel pressure should be above 45-50 at idle.
Sounds like fuel to me though.
I doubt its an oil issue, make sure its at the correct height though. If the HPOP gets starved when the RPM's goes up, you'll sputter.
Old May 2, 2012 | 06:18 PM
Russell ONeill
i havent had time to check fuel pressure. just changed oil and level is exact. how ever i did find fuel in my valley under the turbo
Old May 2, 2012 | 07:13 PM
yoslick's Avatar
yoslick
Rotted hoses or loose/blown banjo washers on your fuel pump.....
Old May 2, 2012 | 07:21 PM
Ken_C's Avatar
Ken_C
Fuel pump weep hole? you really need to check those pressures. our trucks are getting to be quite old so it is possible you got some hoses going. you mentioned that you changed the fuel filter, did you also clean the FPR screen? they can make it run like crap. what did the bottom of the filter can look like? mine had all kinds of garbage in it I had to remove it and clean it out. they can rot out the bottoms if you dont take care of them.
Old May 2, 2012 | 08:18 PM
F350-6's Avatar
F350-6
That's what I was thinking too.
And where did you get your CPS from. We've seen too many problems with the aftermarket ones from the local parts house. Better to stick with Ford or International for the CPS.
Old May 2, 2012 | 10:36 PM
Russell ONeill
i was thinkin new cps wasnt good cause it changed how it ran but still didnt fix my problem. i checked hoses and they were dry but will look more into it. the bottom of my filter bowl was a mess. filter and bowl was loaded with dust of some sort. cleaned it out but didnt check fpr screen. will do that. but just about an hour ago i was lookin at it and remember i had disconnected the clip under the turbo because for a while my truck would make a swoosh noice and turbo wasnt turning on. i connected it back tonight and i got a lot of power back and i can get on it a little but when i get in 5th down the highway it cuts out so i slow down to 50 and it cruises fine. exhaust got louder like it use to be an power is almost all back. could that sensor of some sort also be doin any of these symptoms
Old May 3, 2012 | 05:36 AM
427 fordman's Avatar
427 fordman
No. Lots of guys on here have it unplugged.
railwelder1987
Oct 3, 2015 07:19 AM
hollis4455
May 21, 2009 07:34 PM
jpm2591
Sep 23, 2005 04:11 PM
ahawes
15
Oct 9, 2004 10:12 AM
89Bronco_EddieBauer
1978 - 1996 Big Bronco
May 1, 2003 04:27 PM
