7.3 idi
Old Apr 30, 2012 | 12:23 AM
Bootzz711's Avatar
Bootzz711
7.3 idi
Got a 7.3 idi motor in my truck
Gunna change my valve cover gaskets and my lifter pump gaskets cuz they are leaking and while I got the pump off I'm goin to change it bc it's getting weak
don't want to sink alot of money into this motor as I'm doing a motor swap in the future but I'm looking to get a little mote power out of this for now
What can I do to it?
Injectors? Or something
Just something to help spin my tires a Lil better In the mud
Old Apr 30, 2012 | 12:45 AM
91dirtydiesel's Avatar
91dirtydiesel
Let it breath better, intake, exhaust, and make sure your timing is properly set....so you just need a bit of power now? Gave up on the 500hp ?
https://www.ford-trucks.com/forums/1...ild-build.html
What motor you got planned for it now?
Old Apr 30, 2012 | 02:34 AM
hairyboxnoogle's Avatar
hairyboxnoogle
Grammar goes a long ways towards not annoying people, and spell check is free...
Try tightening your valve cover bolts before just replacing the gasket. WTF is a lifter pump.. do you by chance mean lift pump?
Diesel + turbo = power, want more power, add more fuel / air.
Old Apr 30, 2012 | 02:35 AM
hairyboxnoogle
After re-reading your old thread, heres my advice: Go buy a 90's dodge with a cummins, youll be happier for it.
Old Apr 30, 2012 | 10:23 AM
Bootzz711's Avatar
Bootzz711
Yeah I'm still doing a 500 hp motor. That's why I said I'm doing a motor swap.
I'm going to put a 12v in it and role some coal. That's the motor I'ma build to be around the 500 hp mark.
I'm just looking for a Lil pep till then to help turn my tires.
I was told chamging my LIFT pump that is weak will make a difference.
And I did try tightening my valve cover bolts, that wad my first thought.
The turbo is pricey and I ddont want to sink that much into this motor unless I can find me cheap one for a few hundred or something like that since I'll be putting a cummins I do wanna spend all my time and money In this motor
Old Apr 30, 2012 | 10:35 AM
joe f350's Avatar
joe f350
hope u got deep pockets
Old Apr 30, 2012 | 12:55 PM
Bootzz711's Avatar
Bootzz711
Shouldn't be to bad
Turbo, studs, plate, injectors, few other odds and ends
Them older motors have cheaper parts without them computers in them
Old Apr 30, 2012 | 03:47 PM
joe f350's Avatar
joe f350
what about motor mouts trans adtpers wireing and out little parts thats whats gona add up quick
Old Apr 30, 2012 | 04:15 PM
Bootzz711's Avatar
Bootzz711
Yeah those parts add up quick
For everything I'll need including manifolds and mounts and all in a kit made for my truck will run about 3500$
I found a motor I might be getting tho
108k for 1200$ still in the truck and runs just the truck wa floors real bad
Been sitting for about 4 yrs
Went out there and it crank right up
Hopefully I'll get it this week
Old Apr 30, 2012 | 07:16 PM
'94IDITurbo7.3's Avatar
'94IDITurbo7.3
somebody is pissy today. dang.
i had ZERO problem reading the OP. chill out dude.
Old Apr 30, 2012 | 08:01 PM
hairyboxnoogle
Well lucky for me you chimed in with that helpful information, not sure what we would have done without it... They say great minds think alike... maybe that goes both ways.
Old Apr 30, 2012 | 08:19 PM
'94IDITurbo7.3
hmmmm.....
Jeff Kelly
May 15, 2017 03:45 AM
Bootzz711
28
May 12, 2012 08:34 PM
Deereguy90
Dec 26, 2011 02:15 AM
7.3burnoutbuddy
21
Jan 11, 2006 10:01 PM
Brian1 M
Aug 1, 2004 07:48 AM
