Checking Oil
Old Apr 30, 2012 | 07:49 AM
Tuxedo Scorpion's Avatar
Tuxedo Scorpion
That was my thought exactly. Let it sit overnight then check. Even tho it should be hot, this way no false readings occur from residual oil in the tube.
Old Apr 30, 2012 | 01:44 PM
cford716's Avatar
cford716
Originally Posted by ruschejj
I think you will feel better about your oil once the engine has run for a while and you get the dark black oil. I changed my oil last time and carefully poured the used oil back into the empty containers. We have 13 quart systems, which is 3 gallons and one quart. I was able to fill the 3 gallon jugs but had nothing for the remaining quart. At least I know that I was not making oil and as best I can tell, making oil has not been a subject of concern here at FTE with the 6.7.
I know what you mean about the effort required to check the oil. I'm 6' and it's pretty much all I have to reach the stick. When my back hurts I get pretty angry with the dipstick........
I agree, I thought making oil has not been a concern on the 6.7 as compared to previous engines. Guys that have done an oil analysis have shown very little even after 7000 miles.
Old Apr 30, 2012 | 06:21 PM
Tuxedo Scorpion
i want to change my oil!! not because im worried about the level, but to get some good stuff in there (Mobil1 5w40 TDT) and to get to know what the 6.7 is like to drain/fill. and cause i like being under my truck lol
Old Apr 30, 2012 | 07:31 PM
kper05's Avatar
kper05
Originally Posted by Tuxedo Scorpion
Also i find that checking the oil is a pita compared to my 6.4 because the disptick is nearly on the centerline of the truck, and far enough back that i need and stepstool and to lean to get to it. Im about 5'9" ish....not super tall but not super short.
I'm 5' 8" and I have to stand on the bumper.
The key is, don't slip off; which I've done.
Thankfully in my own garage instead of in public.
Yes, best to check it after a long soak.
Go drive more. You'll be at 5,000 in no time!
Old Apr 30, 2012 | 08:15 PM
Tuxedo Scorpion
im trying!. just hit 900 today. about ready to introduce it to some pullin
Old Apr 30, 2012 | 08:43 PM
cford716's Avatar
cford716
The hardest part of an oil change on the 6.7 is checking the level. Just have a big pan that is open, not the ones that funnel into a hole.
Old Apr 30, 2012 | 08:47 PM
Tuxedo Scorpion
thats all i ever use. but im thinking about the Fumuto valve, and running a tube directly into the oil container for taking to the disposal site. but as typing this i realized i still need the other device cause the filter is underneath like most filters. one thing i miss about the 6.4 was the oil filter. man that was nice.
Old May 2, 2012 | 07:57 AM
darren32's Avatar
darren32
Man all you guys complaining probably have the fancy new cable type dipsticks. Try it with the twisted mess shown below that came on the job 1's. IF you could get the dipstick out of the tube at all, it is usually so seized in there you can't remove it.
Only way to get a reading on my truck is to let it sit over night. But now that I have had it for a while I know I do not need to check it very often. I measure in the correct amount of oil when I change it my truck doesn't make or use hardly any oil. I might check it once or twice between oil changes now (if that). But I change my oil every 6,213.712 miles
Old May 2, 2012 | 08:00 AM
Tuxedo Scorpion
Yup i have the cable type. So glad too. Lemme guess, that interval is 10k kilometers
Old May 2, 2012 | 08:02 AM
darren32's Avatar
darren32
You got it, bad memory so oil at 10,000 kM and fuel filters every 20,000 kM What could be easier?
Thanks
Old May 2, 2012 | 08:04 AM
Tuxedo Scorpion
I do the same. Oil at 5k and filters at 10k. That way i know when its due based on simple mileage figures
Old May 2, 2012 | 08:06 AM
darren32's Avatar
darren32
LOL, I think you and I already had this conversation in another thread.
Old May 2, 2012 | 08:08 AM
  #28
Tuxedo Scorpion
Yup we sure did..
Old May 2, 2012 | 09:18 AM
  #29
kper05's Avatar
kper05
You will notice I said I slipped off once...that was from the job 1 dipstick.
That seal expands in the tube after a week and it takes effort to remove.
Old May 2, 2012 | 09:24 AM
  #30
Tuxedo Scorpion
It was much easier to use tge bumper as a step on the 6.4 because the grille was attached to the hood. Its inadequate as a step on the 6.7 imo
