Cruise control issue
Hi guys i got some problem with cruise control, sometimes it works just fine every ride hit on set up the speed and its perfectly fine, sometimes i have to drive a while or just tap the brake pedal then its working fine, but once or twice didnt work at all, any clue? any ideas what can be bad or some switches or fuses i have to change? can i do it by myself or i have to find some good electric shop? dealer? let me know thx...
Ford cruise control deactivation switches
The switch is simple to change.
However if your vehicle is eligible have the dealer do the change.
It sounds as if the switch on the master cylinder is acting up.
RockAuto Parts Catalog $9.59 + shipping.
i just talk to dealer and 05 ford e-150 its dosnt have recall on cruise controll so i order it MOTORCRAFT SW-6349 and i will change it by myself will see if this will help, btw its just unscrew old one and put the new in it ? i dont have to worry about braking fluid or something? let me know if you know how to do it looks simple but i like to make sure to not put some air in brake lines or something thx
