HPOP problem
Old Apr 24, 2012 | 02:34 PM
church4629's Avatar
church4629
HPOP problem
filled the fuel bowl and drained it off a couple of times, checked all the connections and just keeps cranking over....did I put the gear drive in wrong...I marked the top of it when i took it off and put it back in the same place...can't figure out what else it could be....
Old Apr 24, 2012 | 02:48 PM
church4629's Avatar
church4629
2001 F250 7.3 HPOP O-Rings Non-serv plug
changed out o-rings and non serviceable plug and now it won't start...
<hr style="color:#D1D1E1; background-color:#D1D1E1" size="1"> filled the fuel bowl and drained it off a couple of times, checked all the connections and it just keeps cranking over....did I put the gear drive in wrong...I marked the top of it when i took it off and put it back in the same place...can't figure out what else it could be....Help!!!!
Old Apr 24, 2012 | 02:55 PM
church4629's Avatar
church4629
another thing....
One more thing...I just did this repair this weekend...ran it to town and back and found that I had ruptured the 0-ring on the non-serviceable plug, so I tore it back down and did the kit with the new plug and o-ring from international....it fired right up this weekend when I changed out just the o-rings..but no it won't fire up...
Old Apr 24, 2012 | 07:02 PM
Tom's Avatar
Tom
Hi church4629,
I split this post off into its own thread and moved it down to the 7.3L forum. It's much easier for us to help you out if you have a thread of your own, and the folks down here are the right people to ask!
Old Apr 24, 2012 | 08:01 PM
ChunderDownUnder's Avatar
ChunderDownUnder
Might have to start from the top again m8 and let us know what has happened.
Old Apr 24, 2012 | 09:11 PM
church4629's Avatar
church4629
here's the other info I posted today
https://www.ford-trucks.com/forums/1...serv-plug.html
Old Apr 24, 2012 | 09:21 PM
Shake-N-Bake's Avatar
Shake-N-Bake
It sometimes takes a while to get it fired up again. Have you checked the oil level in the HPOP reservoir? Are you certain the little plastic ball is correctly installed? If that is out of place then it probably won't start.
Old Apr 25, 2012 | 05:31 AM
church4629's Avatar
church4629
back at it again this am...
Going to tear it down again this am...that's what I was thinking last night but was hoping it wasn't the ball issue....it must of moved when i put the non-serv plug back in....read Guzzle's info on his webpage and points to no starts....http://www.dieselorings.com/docs/service_plug.pdf
Old Apr 25, 2012 | 06:12 AM
Crewcab Turbo's Avatar
Crewcab Turbo
Check and charge your batteries you will be surprised how quickly even new batteries will be too low for the computer to fire the injectors. Just because it cranks good doesn't mean it will fire. Put a charger on them and then check there voltage while cranking.
Old Apr 25, 2012 | 08:19 AM
rat49f6's Avatar
rat49f6
If the ball is in the wrong location you should hear pressure leaking off at the front cover
Old Apr 25, 2012 | 01:38 PM
church4629's Avatar
church4629
SOLVED....
thought it was the ball in HPOP last night also after the oil pressure and fuel pressure were all good to the HPOP....had to tear it all back out again...found the ball on the other side...No damage...to the ball...inserted back where it was suppose to be...put it all back in....said a little prayer and ZOOOM.....fired right up.... One thing about it...if I have to do it again...EASY.....once you get past all the stuff to get to it...just follow the directions on here by the others and you can get right through it... Just watch out the pesky little ball doesn't slip over when you change that NON_SERVICEABLE plug....LOL
GEugeneS
Dec 17, 2016 01:07 PM
dothedew192
Nov 13, 2011 04:20 AM
vasten
1997 - 2003 F150
Sep 28, 2010 09:13 PM
outdoormaniac
24
May 14, 2010 03:03 AM
nicksorenson
Jul 4, 2009 12:03 PM
