1998 explore will not start when hot
Old Apr 23, 2012 | 04:45 PM
venmon2's Avatar
venmon2
1998 explore will not start when hot will turn over sputter and die, after 15 mintes it will start right up that was last monday when it was 80 outside it now colder outside has not done it again, the only thing i have seen that temp gage is not going past cold never getting to center it will try and drop back down
Old Apr 23, 2012 | 06:01 PM
aquanaut20's Avatar
aquanaut20
Possibly the CPS is heat soaking and failing... Philip
Old Apr 23, 2012 | 10:47 PM
shorod's Avatar
shorod
These symptoms would also be somewhat consistent with a failing fuel pump (fails to start or stalls when hot). What are the chances you have a fuel pressure tester?
-Rod
Old Apr 24, 2012 | 12:32 PM
aquanaut20's Avatar
aquanaut20
-Rod
How could I have missed such a simple ,, Yes! maybe just getting too old for this ... Philip
Old Apr 24, 2012 | 12:59 PM
shorod's Avatar
shorod
Keep in mind, it was Monday....
-Rod
Old Apr 24, 2012 | 01:44 PM
venmon2's Avatar
venmon2
I do not have fuel pressure tester also it been a week and has not repeat problem it been starting every time, the day it did it was 80 out it right now it 40
Old Apr 25, 2012 | 09:53 PM
Midwest Dually's Avatar
Midwest Dually
I had a Ranger with an issue that when it got up to 80 outside or so, it would die, and not restart. I would usually wait an hour or more, then it would fire up. I got the codes checked and it was the Fuel Pump Circuit Open/ CPU to Ground code (what ever that meant)!
Needless to say, no fuel pressure (using a pen, I opened the pressure relief valve when it died and didnt even get a puff). I replaced the fuel pump, sending unit, filter, inertia switch, all relays, pressure regulator, and installed additional grounding cables to the engine bay, and still got no where. I finally sent the truck off to the junk yard.
I am really curious to see what comes out of this with your issue!
Old Apr 25, 2012 | 10:16 PM
shorod's Avatar
shorod
That sounds like an issue with the driver in the PCM, probably a blown transistor. A new or rebuilt PCM probably would have fixed the issue after you replaced all the other parts. Likely the pump or wiring issue caused the transistor to blow.
-Rod
Old Apr 26, 2012 | 04:15 PM
venmon2's Avatar
venmon2
I will let you know what happin with the explore it been 2 weeks and it still starting, I have no codes and it still only 51 outside
Old Apr 26, 2012 | 09:53 PM
Midwest Dually
-Rod
Good to know! Unfortunately when I posted the problem many months ago, it was baffling to many, so I figured it was time to call it a wash..
I appreciate the updates! I do not like any problem getting the best of me! LOL
Old Mar 24, 2017 | 07:44 AM
savagefan's Avatar
savagefan
OP did you ever fix this? My 98 is doing the same thing.
Old Mar 25, 2017 | 05:49 AM
venmon2's Avatar
venmon2
I had the fuel pump fail 6 mouth
DieselOwnerNow
Dec 9, 2013 05:57 PM
butterbean
Sep 4, 2012 01:31 AM
73strokin
Jun 4, 2010 07:17 PM
gthbryce
Apr 26, 2009 04:22 PM
