91 and older the cab light harness is on the drivers kick panel. Again, brown wire w a single plug
Originally Posted by fordka
right but i have to plugs on the pass side behind the panel. one with lots of wires running to it and one with 2 wires red/blue and white. i was gonna hook it up there because one is sopposed to be fore cab lights and i dont have cab lights and it could be hooked up there couldnt it.
Why not look on the drivers side where there is a good chance you will find the CORRECT connector?
The solid brown wire that goes to the light switch right. Thats no what i was reffering i was asking what those plugs were for behind the pside kick panel. What do i do. Splice the coating and put the wire from the visor on the brown wire. There are 2 wires coming from the visor what do i do with the other
Single brown wire behind kick panel.
One wire gest spiced to it.
Other wire goes to a ground(put an eyelet on and there is a ground screw you can use)
Doesnt matter which wire goes where
