Wiring help
Old Apr 22, 2009 | 02:51 PM
Eclipseb2k2's Avatar
Eclipseb2k2
Wiring help
Okay I am re-doing the wiring harness on my 1977 F-250. When you take the instrument panel off there is a plug that connects all the wires to that printed circut. The connectors at the end of each wire are a crimp on connector with a barb on them. The barb keeps them in the clip. I was wondering what those crimp on connectors are called and where you might be able to get them. I don't want to have to cut them and butt splice the new wires on. Thanks
Seth
Old Apr 22, 2009 | 03:50 PM
73FOMO's Avatar
73FOMO
Maybe they are called a barbed crimp connector....I dunno, but I do think you can bend the barb back enough to slide them out, and then bend back to slide back in. I just reworked all of my harness, but I cut all of that out as I am using aftermarket gauges.
Old Apr 22, 2009 | 03:57 PM
4wydnr's Avatar
4wydnr
Good question, I'm planning on re-wiring my 77 also. So I'm subscribing and hoping for some very knowledgeable person to chime in.
Old Apr 22, 2009 | 06:04 PM
Alvin in AZ's Avatar
Alvin in AZ
****'s got it, I figure. :)
Hadn't messed with those exactly but generally a street-sweeper's
broom-straw works good on that sort of stuff. Modify it if needs be?
Question:
The new wring harness has the clips on the wires but no plastic part?
Alvin in AZ
Old Apr 22, 2009 | 06:39 PM
Eclipseb2k2
I think thats what I am going to do is get the old connectors out. they aren't that hard, then I will just use a butt connector..... I will let you know how it goes.
seth
Old Apr 22, 2009 | 08:23 PM
fmc400's Avatar
fmc400
MSEE
Can I ask what's wrong with the truck in the first place? Stuff like this is often the beginning of an electrical disaster story. If you're redoing a wiring harness, I recommend solder and shrink-wrap instead of butt connectors for two reasons: first, a lot of butt connectors in one spot takes a lot of room; second, butt connectors are a sloppy way of doing things. I think it's okay to do it if you're already in the back of the dash and you don't have a lot of room to work and you're just doing something simple like installing a stereo, but if you've got your wiring harness out on the bench and you're rebuilding everything, there's no excuse. Side note, I don't even consider using butt splices outside of the cab. Anything that gets exposed to the elements needs to be soldered and shrink-wrapped.
Old Apr 22, 2009 | 10:08 PM
Eclipseb2k2
Yeah every thing out side the cab is solder and shrink wrap. I went with a whole new wiring harness because the old one was getting old and starting to crumble. As I peeled back the onion I found that who ever "fixed" the truck before me used all the same color wire.... red. Almost every inch of wire (including grounds) is red. I had a turn signal that stopped working and after trying to trouble shoot it, I decided on a new wire harness.
Side note: When I bought the truck every light and switch except the door switch for the dome light, worked. My hat is off to the guy who could keep all those wires sorted out using only red.
Old Apr 22, 2009 | 10:10 PM
fmc400's Avatar
fmc400
MSEE
Gotcha. He must have done the circuits one at a time. Pardon my ignorance, but what do you mean by "onion"?
Old Apr 22, 2009 | 10:24 PM
murph77's Avatar
murph77
I think he's referring to the ball of electrical tape. That's funny.
I've seen that one before. Old and dried out like the flaky skin of an onion.
Old Apr 22, 2009 | 10:25 PM
Eclipseb2k2
It is just a saying. An onion has several layers as do most problems. As you get to the root of the problem you are peeling back the onion or going layer by layer. At least thats what I take it to mean.
Old Apr 22, 2009 | 10:43 PM
murph77's Avatar
murph77
I agree, but I just tried something over the weekend.
I replaced the old flat four trailer connector (which was dangling from the bumper)
with a nicer looking one that snaps nicely into the hole the old one was dangling from.
There wasn't any slack in the wire, and the easiest alternative was butt connectors.
I injected dielectric grease into the connectors before crimping them,
then used heat shrink around them.
I have an icky feeling in my gut, but I don't pull stuff too often.
When this connection craps out, I'll let you know.
Murph.
Old Apr 22, 2009 | 10:49 PM
Alvin in AZ
Cool, I actually know-ed that one. :)
Your prior wireman wasn't a RR signalman or all the wire would have
been black! LOL :) Inside a signal relay house there's thousands of
wires, and they are all black.
"fourteen flex"
Alvin in AZ
Old Apr 22, 2009 | 11:20 PM
Alvin in AZ
Originally Posted by murph77
I injected dielectric grease into the {butt} connectors before crimping them,
Murph.
That's going to work out real good, IMO. :)
Alvin in AZ
Old Apr 22, 2009 | 11:23 PM
murph77's Avatar
murph77
Alvin in AZ
I hope so, It's just an experiment.
Old Apr 22, 2009 | 11:37 PM
Alvin in AZ
It's gonna be a long experiment is the way I see it, because your butt
connections are better than the factory's ground connections. :)
The main thing is not to ever use the 3M "box" connectors.
Strip 'n' twist 'n' tape is better than those 3M suckers, IME.
Alvin in AZ
