Injector swap question?
Old Apr 20, 2012 | 10:08 AM
superstroker96's Avatar
superstroker96
Question Injector swap question?
I pulled the injectors from my 96 stroker, and I now have a 97. When i pulled them, the motor was on a trailor so it was easy.. How hard is it gonna be with that limited amount of space under the hood to get in there and pry alittle on the injectors of my 97? (I had the injectors out of the 96 re-oringed, and rebuilt and now gonna put them in my 97)
Old Apr 20, 2012 | 10:58 AM
JamesHajek's Avatar
JamesHajek
Gonna be the exact same process... Only thing you will need to do is remove the vacuum box on the passenger side on the firewall right above the back of the valve cover... That will be in the way for that back injector... Other than that, same process...
remove vc's
pull injectors
install injectors
bump starter with glow plugs out to remove fluid from cylinders
install gp's
hook up everything
install vc's
start crankin til she comes back to life...
Old Apr 20, 2012 | 11:52 AM
superstroker96
Thank you sir! The reason I'm swaping is cause of the studder she has at around 2500-3000 rpms.. Other than that and alittle oil use, she runs like hell
Old Apr 20, 2012 | 01:41 PM
Talyn's Avatar
Talyn
Number 8 is the only hard one.
Gotta pull the vacuum box off the wall first.
Do that before pulling the VC also, it makes it easier.
Old Apr 20, 2012 | 01:54 PM
superstroker96
Another question.. My front right tire is leaning in a tad, Ball joints correct?
Old Apr 20, 2012 | 06:00 PM
BlueMule's Avatar
BlueMule
Maybe..........but if it's a 4x4 F250 it could be the bushings at the center pivot or even the spring shackle bushings.
Old Apr 20, 2012 | 07:14 PM
superstroker96
Yea its a 4x4, I wish it had a straight axle under it.
Old Apr 21, 2012 | 05:55 AM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
Originally Posted by Talyn
Number 7 is the only hard one.
Fixed it for ya.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old Apr 21, 2012 | 07:22 AM
Talyn's Avatar
Talyn
Originally Posted by DZL JIM
Fixed it for ya.
I forget they numbered different on diesels. Doh!
sand_fiend
107
Sep 26, 2022 07:47 PM
Cmbrown
Dec 29, 2015 02:43 AM
nossliw
23
Nov 9, 2012 06:50 AM
redman84
36
Oct 11, 2011 10:35 AM
glasseater
24
Jul 23, 2007 08:53 PM
