Injectors In! (formerly: Removing Injectors and then Installing Injectors)
Will hopefully be pulling my injectors tomorrow after work to send them to Jim. Gonna do glowplugs while I'm in there too. I know how to get to the injectors, what wires to remove, and how to free them up. I pulled them from my parts truck to sell to someone. Seeing as how my engine isn't going to the junkyard I want to do it right. What plugs need to be pulled and in what order to drain fluids in there to avoid seizing my engine up?
I never bother pulling any of the rail plugs. Pulling the back injector first will get most of the oil/fuel to fall in the back cylinder.
I know you got a TSC there in College Station. Run down there and see if they have this vacuum pump in stock. LiquiVac Large Capacity Oil Extractor, 8 qt. Capacity - 3000504 | Tractor Supply Company
That will make quick work of getting the fluids out of the cylinders. Then after re-installing injectors, fill HPOP rez and crank it without the glowplugs installed a couple times(with #22 fuse pulled or you can unplug CPS or even leave injectors unplugged. You just don't want the injectors to fire). Once you've done that, re-install glow plugs, #22 fuse, VCs and crank it up.
You'll be fine, just make sure you vac the cylinders good and crank it a couple times without glowplugs in it.
Y'all beat me... Stupid thing wouldn't post. LOL
Yeah put the VCs on loosely. It's just oil and a little fuel that will blow out of the GP holes when you crank it. Remember, your vacuuming the cylinders out first, so there will be not be much fluid to blow out. The fluids will blow out the GP holes, hit the VCs and drain back to the oil pan.
Injectors are out and on their way to Jim!! And I'm about to order new GPs from Clay.
I do have a few questions and probably more later about the reinstall.
Is there a drain plug for the HPOP or am I vac-ing it out the check hole?
When suctioning the rear cylinders am I running the hose down throught the injector cup?
Is there a certain brand of socket thinner than the others for getting the glow plug back down next to the injector?
Guess that's it for now. I'm almost little girl excited about getting em back. Thanks fellas!
In fact, after the new injectors are installed, you'll want to be sure the reservoir is full and then engine disabled (unplug CPS, pull IDM relay, etc.) and crank the engine over so you can start to re-fill the oil rails.
Sorry, can't help you much here. Just don't get your panties all bunched up.
