tow haul light blinking
Old Apr 19, 2012 | 05:52 PM
f350ranchand's Avatar
f350ranchand
Code is p0741 says torque converter clutch solenoid circuit performance or stuck off. Can anybody tell me wat this means and how to fix it n wur its at
Old Apr 19, 2012 | 08:41 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It means the torque converter clutch solenoid is having a problem. Almost certainly that means drop the pan and replace the solenoid. I don't have a diagram to show you which of the seven in there is the problem solenoid.
Old Apr 20, 2012 | 09:21 AM
TAT2DUP81's Avatar
TAT2DUP81
Not to scare u but my tow haul light came on when I first purchased truck. Took in to dealership to get looked at. 3 weeks later and rebuilt trans it was clutch plates that were bad. But at first they thought it was a computer issue.
Old Apr 20, 2012 | 07:50 PM
Mark Kovalsky
How is that related to a code P0741? I don't get it.
Old Apr 20, 2012 | 10:21 PM
f350ranchand
Can ford tell me wich one it is and does anyone know the cost
Old Apr 21, 2012 | 03:58 AM
Mark Kovalsky
If you mean a dealer, then yes, they can. When you go to the parts department to get the solenoid they will have a diagram of the solenoid body and will be able to show you which one it is.
Old Apr 21, 2012 | 06:55 AM
bismic's Avatar
bismic
Here are a few pics that may help:
https://www.ford-trucks.com/forums/m...s-labeled.html
https://www.ford-trucks.com/forums/m...-diagram1.html
https://www.ford-trucks.com/forums/m...-diagram2.html
They are very easy to change.
Drop the pan, yank the filter (which you might consider changing while you are in there) and they are held in place with nothing but a 2-wire electrical connector and a small e-lock snap ring.
SSPC-A: Coast Clutch Solenoid
SSPC-B: Overdrive Clutch Solenoid
SSPC-C: Intermediate Clutch Solenoid
SSPC-D: Direct Clutch Solenoid
SSPC-E: Low Reverse Clutch Solenoid
TCC: Torque Converter Clutch Solenoid
PC-A: Line Pressure Control Solenoid
http://genemohr.com/PowerStrokeDiesel/disassembly.pdf
http://genemohr.com/PowerStrokeDiesel/assembly.pdf
Watch this video (Start at 12:31):
mms://multimedia.ford.com/seopts/Tech14_250k.wmv
You may have to paste the link above in the "Open URL" command of your favorite video player (windows media player will open it automatically).
Also
http://atsg.com//dyndata/articles/pd...0Torqshift.pdf
Old Apr 21, 2012 | 07:17 AM
f350ranchand
Ok thanks for the info
Mikey_23_ny1
Oct 2, 2020 06:08 PM
f350ranchand
Nov 11, 2012 08:54 PM
BBslider002
Feb 8, 2010 02:05 PM
mudmaker
Oct 22, 2009 10:21 PM
jethro
Nov 4, 2003 08:12 PM
