my od light started flashing out of the blue last night and it seemed like the torque converter was acting wierd. So this morning I went out to leave and everything was back to normal for about 2 hours and then it acted up again.
Checked the codes and 0603, 0741 and 0743 came up. Anyone have any help as to what I need to do to fix this.
the 0603 is nothing to worry about.. If you are chipped or using a tuner or have disconnected your battery lately.. Can't help ya with the torque codes..
0741 Torque Converter Clutch Solenoid Circuit Performance Or Stuck Off
0743 Torque Converter Clutch Solenoid Circuit Electrical
0603 Powertrain Control Module Keep Alive Memory (KAM) Error g
Thanks I appreciate the info. I am assuming the solenoid is causing the problem then.
Anyone know what is involved in replacing this? Is it part of the valve body?
If I put a new solenoid pack in I would like to put the transgo kit in as well. I was wondering if it is worth the hassle beings my pickup is pretty much stock.
With 195k on it I don't know if it is worth messing with or not.
