Dad's ZF5 Swap
Old 08-08-2012, 10:23 PM
Gary Lewis's Avatar
Gary Lewis
Gary Lewis is offline
Posting Legend
Power came back after an hour, but I had other things to do so didn't get back to it. Should finish it up tomorrow. Here are some pic's showing the rotary table on the mill and the two holes I got drilled.
  #272
Old 08-08-2012, 10:26 PM
Stangrcr1's Avatar
Stangrcr1
Stangrcr1 is offline
Are all the holes evenly split? Usually there is one or two that are offset a bit due to balance. I ferget, is that motor internal balance?
  #273
Old 08-08-2012, 10:34 PM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
The normal spacing is 60 degrees, but one is at 57, which makes its spacing to the next one 63 degrees. Easy on the table as each turn of the crank gives 4 degrees, so 15 turns on most and then 14.25 turns and 15.75 turns.
I worried a bunch about getting the spacing wrong, like backwards. But, using the transfer punch fixed that easily. Now I just have to make sure I'm drilling where the marks are.
  #274
Old 08-09-2012, 01:35 PM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
Machining Done!
Got it all done today, including chamfering the flywheel. Attached pictures are:
  • Rear view of spacer. Note the .125" chamfer between the pilot, the vertical part, and the flange that runs horizontally. This was planned to be .100" but I made it larger to give more metal in the "sliver" between the front and rear chamfers. The drawing shows the sliver to be .145".
  • Front view. The chamfer in the pocket was one of the hardest parts of the project.
  • Flywheel in lathe with gap in bed removed. The gap had never been out and it took some "persuading" as the paint was thick and part of the backsplash had to be cut away to get it off. Then I discovered that it took my longest boring bar to reach the work. Not surprising then that you can see some chatter in the cut.
  • Original .050" chamfer on flywheel. Sorry for the blurry shot, but you can sorta make the chamfer out.
  • New .125" chamfer to match that of the spacer.
  • Spacer on crank proving bolt holes are perfectly placed - they went in w/o any issue whatsoever and I turned them in by hand.
  • Spacer on flywheel with no clearance between spacer and flywheel, proving the chamfer is adequate. I can't get a .002" feeler gauge between them and there is a significant "clack" when it slides home and hits the flywheel all around the flange at the same time.
This is a perfect point to take off for a long weekend to visit the grandtwins as it is their first birthday. Then when I get back I can finish putting Rusty's engine back together, pull Dad's truck in and pull its bumper, grill, radiator, exhaust system, engine, transmission, t-case, seat, carpet, steering column, brake pedal and bracket, etc. And then the work will begin to put the new engine, ZF5, rebuilt t-case, etc in. Sounds like a lot of WORK! (I see Maynard G for some reason.) But, it was work to get to this point and I'm thinking I'm about half the way there so it must be downhill from here - right?
  #275
Old 08-09-2012, 01:42 PM
KingBigJoe's Avatar
KingBigJoe
KingBigJoe is offline
Nice work. I can see the flywheel chamfer with no problem. Now to wait for more of your progress...
  #276
Old 08-09-2012, 02:28 PM
Rogue_Wulff's Avatar
Rogue_Wulff
Rogue_Wulff is offline
Looking quite awesome!
  #277
Old 08-09-2012, 06:40 PM
ArdWrknTrk's Avatar
ArdWrknTrk
ArdWrknTrk is offline
pedant
Amazing progress Gary!
  #278
Old 08-09-2012, 07:50 PM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
Thanks. Progress won't happen for a few days given our trip, but I'll get back at it some time next week.
Thanks. Now I'm wondering what I should coat it with to prevent it rusting. Gotta keep it thin or it won't fit in the flywheel or on the crank. Maybe I'll just put anti-seize on it.
Are you saying it is amazing because I'm making progress? How many pages did it take?
  #279
Old 08-09-2012, 08:00 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Nineteen pages equals 2 & 3/8 eight page analyses...
  #280
Old 08-09-2012, 08:18 PM
Fordzilla80's Avatar
Fordzilla80
Fordzilla80 is offline
Aluminum stock and custom made spacers excite me as much as the next guy, but there's just something about pics of a dressed 351M/400.
  #281
Old 08-09-2012, 08:31 PM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
Well, the material for the spacer is steel. Aluminum would have been easier to machine but I didn't think it would be solid enough for that application.
But, the 351M is next on the agenda, and I hope to have it dressed next week so I can start disassembling Dad's truck.
  #282
Old 08-09-2012, 08:36 PM
Fordzilla80
I want pictures!
  #283
Old 08-09-2012, 08:43 PM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
I want pictures!
Don't have a camera and don't know how to post pictures if I did.
Ok, I understand. I'll see if I can remember to take a shot or two at the end of each day. I wonder if I'll run into a limit on pictures or storage first - currently have 268 pics taking up 34 Mb. Anyone know the limits?
  #284
Old 08-09-2012, 08:46 PM
Fordzilla80
Not a problem, Imageshack has free accounts.
  #285
Old 08-09-2012, 10:42 PM
ctubutis's Avatar
ctubutis
ctubutis is offline
ImageShack allows 500 free, need to pay after that.
I've seen the FTE limits talked about in the mods forum but don't recall what they are.
Quick Reply: Dad's ZF5 Swap
