Fuel bowl fitting
Old Apr 18, 2012 | 09:17 AM
JT250's Avatar
JT250
Fuel bowl fitting
I am wanting to check my fuel pressure today. I have looked through pages of threads but cont find what fitting/adaptor is needed for the pass side port on the bowl. I don't have much time today so I can't be running back and forth for parts.
Any help?
Thanks!
Old Apr 18, 2012 | 09:48 AM
mueckster's Avatar
mueckster
It should be a #4 O-ring Boss. It is the same size as the HPOP reservoir plug.
Old Apr 18, 2012 | 09:50 AM
JT250's Avatar
JT250
Originally Posted by mueckster
It should be a #4 O-ring Boss. It is the same size as the HPOP reervoir plug.
Thanks!.........
Old Apr 18, 2012 | 10:47 AM
woodnthings's Avatar
woodnthings
The threads are 7/16-20 thread. You can get a standard #4 JIC (flared fitting) from a hydraulic supply or if you go to the hardware store you can get flared fittings in brass. Then you just need an o-ring to place over the threads. The o-rings are AS568-904's. Like mentioned, you can pull the o-ring off the plug you remove and reinstall it when complete, just don't damage it.
I make my own fittings using JIC fittings as they are easy to find. You can leave the flare portion as it does not interfere with anything in the fuel bowl.
After machining off the flare.
This is a SAE 37 degree (JIC) flared fitting. You can also use 45 degree flared as they both have 7/16-20 threads for #4 or 1/4" adapters.
Old Apr 18, 2012 | 11:32 AM
JT250's Avatar
JT250
Got a kit from harbor freight. Going out to see if it will fit. If not I will have to go get a fitting like in the pics.
Thanks.
Old Apr 18, 2012 | 01:33 PM
JT250's Avatar
JT250
Fuel Pressure Tester & Fuel Injection Pump Tester
That is the kit I got from Harbor freight. It did have a hose that screwed directly into the passenger side port but then I could not connect to the gauge. So I ended up having to get a 1/4 x1/4 male to male flare fitting. Then I could screw that into the port and use a different hose supplied with the kit.
This post is for else looking for this info in the future.
Old Apr 18, 2012 | 02:17 PM
PaysonPSD's Avatar
PaysonPSD
If that HF stuff doesn't work out see these fittings from Guzzle's Dieselorings.com
Pressure Port Adapter - Straight 1/8 FNPT
Pressure Port Adapter - 90 deg elbow x 1/8 FNPT
Old Apr 18, 2012 | 05:36 PM
JT250's Avatar
JT250
Thanks it worked pretty well
I. I found that fuel pressure at idle is 70. Need to get an in cab gauge someday when I can spend the money.
nathanr561
Aug 3, 2019 05:18 PM
beanhead6D5
79
Feb 1, 2015 03:06 PM
spdmpo
106
Apr 10, 2014 03:34 PM
rideracelivemx7
19
Feb 24, 2011 06:44 PM
Fordbronco69
21
Nov 30, 2009 01:13 PM
