hey guys need help again
Old Apr 16, 2012 | 12:02 AM
Dbailey's Avatar
Dbailey
Hey guys went out with some friends and did little mudding and went threw a water hole and suck water in the intake. What can I do to get it tp turn over. It act like its stuck please help ASAP thanks in advance
Old Apr 16, 2012 | 02:38 AM
tecgod13's Avatar
tecgod13
Uh-oh better hope you didn't bend a rod. Water doesn't compress like air does. The water 'hydrolocked' the engine, basically filled a cylinder and with the valves closed the piston can't compress so just stops dead.
If there is no damage, all you have to do is pull the glow plugs and turn it over. The water will spray out of the glow plug holes. Reassemble, cross your fingers, and see if it fires.
Old Apr 16, 2012 | 11:45 AM
Dbailey's Avatar
Dbailey
Ok I will give that a try
Old Apr 17, 2012 | 10:10 AM
38Chevy454's Avatar
38Chevy454
If the engine was turning when it hydrolocked, good probability that you bent a rod. The momemtum of crankshaft and bottom end components mass want to keep turning and the piston won't go up further. Something has to give and the rod bends.
Do just as tec suggested, remove the GPs and turin it over. That will give the water a place to go.
Old Apr 17, 2012 | 10:27 AM
Dbailey's Avatar
Dbailey
Well got the water out but now it overheats thank it done. Got 500.000 miles plus hope its ok had this motor since I was 16 now I am 28 and its been threw a lot. I thank its the second time it had water lock like that by my dad and now me. That is a **** pour design by ford I thank
Old Apr 17, 2012 | 10:29 AM
Dbailey's Avatar
Dbailey
Gunna put new oil and filter cause the old oil was pretty than for some reason maybe water was mixed with it I am not Shure. Did not look like water
'94IDITurbo7.3's Avatar
'94IDITurbo7.3
how is you driving threw a mud hole, sucking water into the intake, a bad design by Ford?
Old Apr 17, 2012 | 10:39 AM
38Chevy454's Avatar
38Chevy454
water in oil will make it turn milky dark brown color, at least on gassers. Since the diesel oil is so black it may be milky black color.
Old Apr 17, 2012 | 10:43 AM
Dbailey's Avatar
Dbailey
Not really milky though at all I mean
Old Apr 17, 2012 | 10:52 AM
Dbailey's Avatar
Dbailey
If I find a motor for a reasonable price here in topeka Kansas I will route the air intake system for Shure. Got a 460 motor that came from a 89 dully f350 would it work if I put a intake and car on it both got c6 trans
Old Apr 18, 2012 | 06:24 PM
Dbailey's Avatar
Dbailey
ok guys got the number for the compression test. here they are. Let me no what you guys thank
310 390
320 420
340 400
400 390
front of motor
thanks again
Old Apr 18, 2012 | 09:31 PM
86f250XLT-4x4's Avatar
86f250XLT-4x4
All over the map in my opinion especially the two in the back at 320 and below
Old Apr 18, 2012 | 10:13 PM
RCrawler's Avatar
RCrawler
What a ****-poor design. Only lasted half a million miles.
I have a spare 7.3 I'd sell. Has some miles on it, but still ran. $400.
Jason
Old Apr 18, 2012 | 11:50 PM
Dbailey's Avatar
Dbailey
So is there a way to see if the rods are bent. What do the 6.9 diesel usually run compression wise. Where about do u live at
Old Apr 18, 2012 | 11:57 PM
Dbailey's Avatar
Dbailey
I just don't seem to thank its nothing major because it will start right up no noise or nothing. Does not even smoke. Just seems like its cutting out but not to bad just like a little mis or something. Pull the valve cover off. Took the push rods out and check them on a piece of glass and they all seem to be straight. What can I do now
Thanks in advanced
