Hey guys its me well the motor is toast its knocking now. So I traded a 2004 ktm dirtbikes I had for a new reman engine 0 miles. A college here in town at a diesel tech school had it so I traded my bike for it. One wondering what a used or new reman motors cost. And what does it cost to rebuild yourself. So I gotta take waterpump exhaust manifold and t stat and top radiator hose off my used motor and put on the new reman and then ill be good to drop the new reman in. Oh and what is the fluid you add to radiatoe called so it don't cavatat or whatever I have read about cavatation. Thank again guys in advanced
Product Description
Baldwin BTE Liquid Coolant Additives are designed to provide superior protection against cavitations erosion, corrosion, scale and foaming. They reduce foaming caused by piston slap and the circulation of the coolant. These coolant additives eliminate pump seepage caused by granular precipitation on seals due to the lowest total dissolved solids."
Provides superior protection
Resists cavitations, erosion, corrosion, scale and foaming
Reduces foaming caused by piston slap and the circulation of the coolant
Eliminates pump seepage caused by granular precipitation on seals
Highly durable "
Generically called "SCA" or "supplemental coolant additive" for long written out. An easy solution is to just get Fleetcharge antifreeze which is premixed (don't dilute with water), low silicate formula and has SCA's in it. You will need about 8 gallons for a complete fill.
