hey boys and gals at work i was roaming threw some stuff and i had found four injectors they were e code and they are all brand spankin new how good are the e code injectors anyone have any idea?
they are very good injectors.
they are the factory 92 (iirc) - 94 factory N/A injectors.
put 'em in and run 'er! just buy 4 more E codes to make a matching set.
realistically,there probably isn't 5 hp difference between the codes.just run a matched set is the main thing.
here we go; you can find the other 4 you need here: http://www.mwfi.com/dieselPage/nav_73.htm
#STA29455
you'll need the install kit (return line system) for your truck.those look priced good there too.good grade kits from my understanding.dipaco.
don't forget replacing injectors is said to make the ip work harder than trying to pop open old worn out injectors,so if the ip is older,it could be the end of her shortly.
so..........finding 4 new injectors is just a good start,but your hundreds away still from a tune up.
LOL I just bought a full set from The Diesel store and a return line kit for the same amount I could of bought only 3 injectors and a return kit from Advanced Auto! And they also have the metal pressure lines...I wish I would of found them a few months ago, I bought a used one for 30.00
