6.0 chugging
Old Apr 15, 2012 | 09:44 PM
pvfd1286's Avatar
pvfd1286
6.0 chugging
I have a 06 six speed new clutch and new ficm. Truck wants to chug or dog hunch while pulling loaded trailer on inclines or starting off on incline. Any suggestions
Old Apr 16, 2012 | 02:31 AM
bismic's Avatar
bismic
Check for codes. Do you have access to a scan tool?
Old Apr 16, 2012 | 07:57 AM
pvfd1286's Avatar
pvfd1286
Yes how big of a problem can the egr valve cause
Old Apr 16, 2012 | 01:53 PM
pvfd1286's Avatar
pvfd1286
Scanned truck egr valve had a code could clogged egr valve be causing these chugging issues while towing on inclines
Old Apr 16, 2012 | 10:24 PM
devils toy's Avatar
devils toy
Had same problem. The FICM was bad along with 4 injectors.
Old Apr 17, 2012 | 10:15 PM
nitrogen's Avatar
nitrogen
yes the egr can very definitely cause this. pull the valve, clean and inspect. let us know how that works for you, before you start panicking about FICM's
Old Apr 17, 2012 | 11:05 PM
pvfd1286's Avatar
pvfd1286
Excuse my ignorance by the egr sticking what is the mechanical reason for it to cause the chug or skip
Old Apr 17, 2012 | 11:36 PM
nitrogen's Avatar
nitrogen
don't know why but I have had various surging symptoms cured by cleaning or replacing the egr valve
Old Apr 17, 2012 | 11:39 PM
BLADE35's Avatar
BLADE35
By letting to much exhaust gas back in
EGR= Exhaust Gas Return
Since Exhaust gas has been combusted prior to going back into the intake manafold there is nothing left to Burn again so you dont get Good combustion or a Weak BOOM in cylinder
They get a carbon buidup on them and start to stick open letting to much uncombustable material back in
so Pull and clean it dont get cleaner in upper electronic part threw the weep holes just clean lower valve part
Old Apr 17, 2012 | 11:40 PM
pvfd1286's Avatar
pvfd1286
Thanks for info
Norton72
Jun 7, 2018 08:29 AM
6.0fanboy
Feb 4, 2017 12:17 PM
Afreis
Oct 29, 2015 06:50 PM
rsplash40
May 25, 2015 09:45 PM
2000 roadking
Jun 16, 2011 07:20 PM
