Remove play in steering column?
Old Apr 15, 2012 | 06:41 PM
RichardPerry's Avatar
RichardPerry
There is some noticeable "play" in my steering column (73 F250 2wd auto). I don't know a better way to describe it. I can hold the steering wheel and move it up, down, and side to side. Everything works correctly, but the movement creates a rattle on bumpy roads, one that I would like to eliminate.
It this just a loose part inside the column, or does this require some other repair?
Old Apr 16, 2012 | 08:21 AM
OldStyle's Avatar
OldStyle
Rusty Roller
I believe there is an upper bearing which can be replaced but I don't have a part number for you. link> LMC <link or="" one="" of="" those="" outfits="" should="" have="" one.="" <link or="" one="" of="" those="" outfits="" should="" have="" one.="" link or one of those outfits should have one.
Old Apr 16, 2012 | 01:22 PM
84espy's Avatar
84espy
I also had play in my steering on a 75 that I had just purshased. It turned out to be the rubber bushing between the box and the coloumn. If this is your issue, then a replacement is available at most auto parts stores.
Old Apr 16, 2012 | 02:28 PM
76F100guy's Avatar
76F100guy
I have this same problem in my '76. I assumed it's the bushing, since the wheel turns smoothly; otherwise, I'd figure it's the upper bearing. I ordered the bushing from Dennis Carpenter, and it's rubber. Does that thing really eliminate the play at the wheel? I was expecting hard plastic.
Old Apr 17, 2012 | 08:09 AM
mountainsportsman's Avatar
mountainsportsman
Is it the column itself or the steering wheel and the column guts only? Check to make sure the hanger that attaches the column to the underside of the dash is tight. You have to remove the plastic cover to get to it.
Old Apr 17, 2012 | 09:35 AM
RichardPerry
It is not the column itself on mine. The steering wheel is tight. There is just this slight play, and therefore rattle, and a bushing or bearing would make the most sense from the sounds of it.
Old Apr 17, 2012 | 01:28 PM
76F100guy's Avatar
76F100guy
It's not the column itself on mine, either. You can see lateral movement of the wheel relative to the column. And, yes, the wheel is on tight
Old Apr 17, 2012 | 01:46 PM
bamaf150's Avatar
bamaf150
There is a spring and the signal cam missing under my wheel, this creates a small amount of play
BlackBeest
6.7L Power Stroke Diesel
Jan 26, 2019 08:46 PM
Spindoctor
2009 - 2014 F150
Jan 11, 2016 07:26 PM
Scratcher
Nov 28, 2010 08:58 PM
frdnut
May 19, 2006 12:25 PM
'70_f-100
Jun 19, 2005 01:38 PM
