wheels
McDoogle
Carpenter, AFAIK, only repro's: 6A-1130-A stainless steel "innie" (1948/52 F1, 1953/56 F100) and 9 1/2" C3TZ-1130-A (stainless steel innie bottlecap).
6A-1130-A will also fit 1957/66 F100's with innie wheels. What outie hubcap used from 1966 thru 1996 is smaller in diameter than these two innies? None.
Thanks
McDoogle
C3TZ-1130-A .. 9 1/2" O/A diameter Stainless Steel "Innie" Hubcap, has 12 of these \_/ around the outer edge. Peeps call this hubcap a "bottlecap."
Innie = So called because the hubcap snaps over tabs located on the inside of the center section of the wheel.
Your truck has "outie" wheels, because the hubcap snaps over tabs located on the outside of the wheels center section.
Outie wheels were introduced in 1965 F100's, but innie wheels were also available. 1965/66 F100 Custom Cabs with outies came with C4AZ-1130-A 10 1/4" O/A diameter Stainless Steel hubcap.
This same hubcap was also used on 1964 Ford Custom/Galaxie/Galaxie 500, not reproduced. Standard Cabs came with painted versions of this hubcap, not reproduced.
the hard to find "Innie" rims. (mind you....mine were for an 8 lug F250)
It took me about 6 months to find a full set of them, and I even had to have 4 shipped to Southern California from Ohio.
They are a one-piece rim (not split rims) , and what makes them so hard to find is they are tube-type rims, so they were used with tubed,
bias ply tires, and when they went flat, a lot of moisture got into them, usually around the valve stem area, and the corrosion is usually so
bad, the wheels are not usable. It is also not recommended to use them with Radials...ya, I know a lot of you guys do it, but that advice
comes from a custom wheel builder I know with over 20 years experience custom building wheels.
You could go the new route...try Wheelsmith in Corona, CA or Wheel Vintiques.
Hope that helps...
Jason
Why didn't you ask me? I know where dozens are, coulda got all 6 locally at a LA LA Land truck dismantlers yard. Same location since 1929, same family ownership.
(sigh) Geez Louise.
I do have to add that it only cost me a small amount to ship them from Ohio due to a Fedex screw-up. Are the ones up there F250 8-Lugs?? In all my trips to the yards, I found one 8 Lug, but did occasionally find 5 lugs
that were toast....they are almost always corroded badly near the valve stem hole or the rivet areas for the center section.
Jason
Jason
Long time truck dismantlers yard doesn't usually allow peeps to walk behind the front counter, look around inside two large 2 story buildings, stroll around in the yard.
Because of this, there are TONS of old parts there that most peeps are unaware of, some of which are NOS gen-u-ine Ford.
Most peeps doesn't include myself because I've been hitting this yard since 1967, was once one a my wholesale accounts.
Also doesn't include "Squire" Don (camperspecial65), Dave (garbz2), Robert (gangstakr), cuz all have been given the grand tour, and once the owner met them, they can go back, stroll around without me.
Dave bought a pair of used minty 1968/72 Crew Cab rear doors (super cheap!), 3 NOS lower valance panels for 1961/66 4WD's (real cheap!). Robert has bought all sorts of stuff.
"Squire" Don was pokin' around in the used fender section, found six L/H 1961/66 45" opening radius fenders that I had no clue were there, cuz I usually don't look for/buy used parts.
