installing a brake controller
Old Apr 13, 2012 | 04:11 PM
thebandit343's Avatar
thebandit343
I am installing a trailer brake controller and have run the blue wire up front and I know the black and white wires got to the battery. My question is on my 96 f250, what color wire on my truck does the red wire go to? I was told it goes to the brake switch, but there are 2 wires there and I do not have a service manual or wiring scmatic to look at.
Old Apr 13, 2012 | 05:21 PM
Diesel_Brad's Avatar
Diesel_Brad
Your truck has a plug under the dash that you PLUG the brake controller into. No need to cut or spice ANYTHING
Old Apr 13, 2012 | 06:44 PM
metriccar's Avatar
metriccar
Are you talking about the 3 pin connector under the dash that have the "trailer" labels on them? Were these 3 wires originally unconnected to anything and siliconed off? I'm having trouble after uninstalling a brake controller someone else put on and wasn't done right (wires disconnected, my wires ended up frying, etc).
Old Apr 13, 2012 | 09:45 PM
thebandit343
my brakecontroller is a universal and only has wires coiming out of it, no plug. Where is the plug you are referring to?
Old Apr 14, 2012 | 06:54 AM
Intimnasc's Avatar
Intimnasc
You have to buy a pigtail for the factory connector. I just installed one in my 94.
Simular to this.
http://www.hitchanything.com/1996-Fo...ord-20260.html
Old Apr 14, 2012 | 07:04 AM
Diesel_Brad
Simular to this.
1996 Ford F-150 Brake Control Wiring Adapter, Ford 20260 :: Vehicle Trailer Wiring Harnesses :: Trailer Wiring :: Hitch Anything
Correct. you need the adapter show above to butt connector to the back of the brake controller. The it PLUGS right into the trucks harness under the dash
eforer
Jul 20, 2019 04:52 PM
jayro88
All Things Towing
May 9, 2013 09:11 AM
dyhrdford
All Things Towing
21
Aug 14, 2010 07:12 PM
scottddove
All Things Towing
May 16, 2006 12:55 AM
merlinke
Electrical Systems/Wiring
Jan 30, 2004 08:31 PM
