Just hit 220k
Old Apr 11, 2012 | 01:47 PM
bakerbuilttracks's Avatar
bakerbuilttracks
Just hit 220k
Hey yall just hit 220,000 mi on my late 99 psd. My mods are listed below and I plan on doing the hutch and harpoon in the next few weeks. Question is what are some other things I should be lookin todo. Im thinkin .50 cent mod which ive never had any trouble from the pin connector clips. Also thinkin turbo rebuild. When should that be done ? Anything other that yall can think of for my mileage would be awesome.
Old Apr 11, 2012 | 04:41 PM
Brother Les's Avatar
Brother Les
Do an oil and filter change in the tranny.
Old Apr 11, 2012 | 08:13 PM
F350-6's Avatar
F350-6
Change all the fluids (all of them). Change the serpentine belt. Inspect and change any hoses that look suspect. Do the 50 cent mod and re-torque the injectors and rockers.
I've got almost twice the miles you do and haven't had to rebuild my turbo yet. Just take care of your truck and it will take care of you.
Old Apr 13, 2012 | 10:58 AM
bakerbuilttracks
i had my tranny rebuilt bout 25k ago and do need to probably change the fluid and filter. As for the other fluids....
-Oil and oil filter every 5k
-Fuel filter every 5k with oil change
-Diff oil needs to be done.
-Belt i replaced bout 3years ago with water pump
-Now the .50c mod i really want to do. i need a good link on a write up
-Re-torque the injectors and rockers i need a write up link swell
Other than that anything else ?
Old Apr 13, 2012 | 11:09 AM
Brother Les
Here you go:
https://www.ford-trucks.com/forums/925570-need-to-pull-a-valve-cover.html<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Old Apr 13, 2012 | 11:24 AM
bakerbuilttracks
awesome thanks when i get some time i will be doing the 50cent and others
Old Apr 13, 2012 | 11:39 AM
bakerbuilttracks
So by looking at the pictures on the 50cent mod when i go to install the quarter how is this done. Do i disconnect the connector slide in the quarter then connect it back ? Just want to make shure i do it right. Im also guessing the connectors will be brittle swell and i DONT want to break anything
Old Apr 13, 2012 | 12:32 PM
Shake-N-Bake's Avatar
Shake-N-Bake
The quarter goes in last....right before the valve cover is put into place.
Take caution when reinstalling the valve cover. It's pretty easy to accidentally bump one off the injector connector retaining clip and then have it fall out shortly after you get it running again. #7 seems to be the one that catches me out from time to time...
Shawn MacAnanny
34
Jan 14, 2018 12:24 PM
BrandonsE99psd
Aug 18, 2017 08:10 PM
F250_
Mar 5, 2007 08:25 PM
05f250fx4
Oct 15, 2006 07:18 PM
RussB
Oct 5, 2004 08:49 AM
