oil pan coating
Old Apr 4, 2012 | 08:13 PM
96f-150's Avatar
96f-150
oil pan coating
I have read countless threads on oil pan rust........mine is toast. 2002 F-250 7.3. New pan is on the way and my big question which is kind of hit and miss on searching is what would be the best prep I can do while the pan is sitting on the bench. I will have close to $1,500 in this by the time its done and don't want to do this again so I would like to do anything possible to prevent rust any way i can. Heard great things about POR 15 but I think that is more for "rusting" metal and not a new part. Is there something out there better suited for this?
Old Apr 4, 2012 | 08:38 PM
MikeSDK's Avatar
MikeSDK
One great way to prevent it is to wipe it down frequentlywith with motor oil. I used to do that with a previous 7.3 i had, and the pan was spotless and shiny when i traded it in on my current truck. I did POR-15 on my current truck with good results.
Old Apr 4, 2012 | 09:26 PM
snakedoc's Avatar
snakedoc
i have seen them powder coated.
i just sanded and primed then top coat high grade paint.
Old Apr 4, 2012 | 09:29 PM
woodnthings's Avatar
woodnthings
The biggest problem is the paint gets damaged and then the rust starts. You can use the POR 15 to toughen it up. Bed liner works too! If you have some time, prep it and take it to a spray in liner shop. Usually they will spray small parts for a good price if you can leave it with them for a few days. Just keep the plug and bolt holes clear.
Old Apr 4, 2012 | 09:59 PM
cutlass's Avatar
cutlass
I just got done having my oil pan coated with Line-X. I think it will hold up to all kinds of debris/chemical bombardment underneath the truck. My local Line-X shop charged me $50 and they did a great job! Of course I brought in the pan already off of the truck and they were able to get it coated thoroughly..
Drake
Old Apr 4, 2012 | 10:06 PM
indyF-350psd's Avatar
indyF-350psd
you can't fix stupid!
yup....line-x'd for 50 bones.....
Old Apr 5, 2012 | 06:00 PM
spooky01's Avatar
spooky01
anyone have any real first hand longevity info/results regarding por-15
Old Apr 5, 2012 | 07:31 PM
psd76's Avatar
psd76
I had my new oil pan powder coated before it was installed 3 years ago and it still looks like new.
Old Apr 5, 2012 | 08:41 PM
HKusp's Avatar
HKusp
I POR 15'd mine a couple of years ago and it looks terrible again. I followed the directions to a T and there is a lot of rust back on there again. Now I plow and salt in the winter and while we didn't have any this year, we had lots 2 years ago and good amount last year so the salt was tough on my truck. Overall, I am not impressed with the POR 15 job.
Old Apr 6, 2012 | 12:41 AM
big poppa's Avatar
big poppa
My Rust Bullet application I'd say 3 years ago is holding up good. Applied 3 coats back then and I got some rock-stone chips now that are showing rust again, in those chips, but overall happy with the results. I'm going to sand it down again and reapply my other small can. I got the starter kit, was more than enough, still have one can left.
Old Apr 6, 2012 | 10:35 AM
Cell's's Avatar
Cell's
I did the Rust Bullet also while it was still in the truck . What a pain to do because I could not cover the whole pan but got most of it along with some on my wrists . Done it last fall and so far it still looks alright . I put on 2 coats of the stuff . Just trying to prevent having to remove the pan .
Old Apr 6, 2012 | 01:20 PM
SteveH-CO's Avatar
SteveH-CO
Regardless of the coating, you need to inspect and reapply, if you live a salt-prone state. No corrosion protection (IMO) is a 'do it once and forget it' deal, if you intend to keep the vehicle a long time.
Old Apr 6, 2012 | 03:44 PM
ToMang07's Avatar
ToMang07
I have been going back and forth between POR-15 and Bed Liner. I'm leaning towards POR-15 because of cost, AND that it it had a temp rating.
Old Apr 6, 2012 | 06:02 PM
big poppa's Avatar
big poppa
I got to say, if my pan was off, the bedliner coating looks great, and funtional if the pan is preped right from the start. Nice job and pics from all that did this.
Old Apr 6, 2012 | 09:12 PM
96f-150's Avatar
96f-150
The truck is low miles (110,000), paid off, and don't plan on replacing any time soon (last few years has been about 5,000 miles a year) so i don't mind spending a little now to make sure i don't have to do this again.
That being said, im between powder coat and bedliner. I have a powder coat company that i have worked with before and there is also a local bedliner place. Im sure both will probably be great but would one be better than the other?
Thanks for all the help, I don't know what i would do with out this place.
