Pushes left
Old Apr 10, 2012 | 06:36 PM
swunderle's Avatar
swunderle
Pushes left
Ok guys I got involved in this problem today and wondering if anyone has a suggestion. We have a 2008 F450 with a rescue box on it. It has a kelderman air suspension on the rear all bushings look good, ride height is good. Unit had a bad tie rod end so I had them all replaced and a 4 wheel alignment completed. Truck drives straight under normal driving conditions. Here is the problem. If you are driving along and push accelerator to floor truck pushes left hard enough you have to correct to the right. When you ease off the throttle truck stops going left and you have to steer back left. Is my rear axle having some kind if limited slip problem?
Old Apr 11, 2012 | 02:40 AM
xlt4wd90's Avatar
xlt4wd90
I know you said the bushings looked good, but it sounds more like the rear end is shifting around under acceleration. Can you have someone watch it from the sides for any fore-aft axle motion as you accelerate from a stand-still?
I've had a failing LSD try to steer the car, but that was under very hard acceleration that would alternately lock and unlock, sometimes spinning a tire on each side. The car did in fact have squishy bushings in the rear suspension.
Old Apr 11, 2012 | 06:49 AM
critterf1's Avatar
critterf1
Have you checked the U-bolts on the rear springs? Something is shifting.
Old Apr 12, 2012 | 05:49 AM
swunderle's Avatar
swunderle
U bolts are all tight no movement. There are no springs this is an air ride system with a 4 link. All bushings look good
Old Apr 12, 2012 | 08:12 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
One or more of the bushings are bad allowing the axle to pivot.
muth_33
Mar 31, 2016 10:36 AM
MikeVT
Sep 18, 2011 05:52 PM
catfish101
Aug 20, 2007 10:49 PM
Canadianice
Bronco II
Mar 8, 2005 12:09 AM
Roamer
Aug 9, 2004 06:15 PM
