2002 Ranger; Help Troubleshoot Why A/C & Heat Blows Thru Defrost Only
I have a 2002 Ford Ranger 3.0L truck that, all of a sudden, has a problem with the HVAC system that blows air only thru the defrost vents even when selecting any other vent levels (defrost, face/middle or floor levels).
I did find a thread on another forum regarding this problem, only it was for the 95-01 Ranger model years, yet they say that the 2002 Ranger is not the same as those earlier models.
Any and all help and/or advice is greatly appreciated.
Thank you for your help. Great call, that's exactly what happened. The supply line to the vacuum reservoir was cut in two near the vac reservoir.
Would you happen to know where I could find these vacuum reservoir PVC lines? I've been doing some searching online, but I could not find any place that carries them. These lines should be common replacement items.
Thanks again for your help.
minnesotafisherman
10-17-2012 11:08 PM
joshhaywood
1983 - 2012 Ranger & B-Series
01-23-2006 06:32 PM
