anyone know where i can find a pic of a stock module hooked up to the stock harness. im having probs wiring it up to my stock distributor. i had to rewire this truck cuz of a fire under the hood.
I am a little confused. A 73 didn't have a module, it had points. If it has a module in it then it must have been modified. If so, you need to post a picture of it so that we can see what it is before we can help you. Am I wrong here?
Nope, you're correct. In '73 it was points, '74-'75 points standard, electronic optional, '76 electronic (Dura-spark I) standard, points not offered.
Corrected time line, electronic ign. not standard until '76.
Reason: correction
Like the diagram, nice and clear. I have six or seven of them.
dipstick66: If I recall correctly, solid state ignition didn't come out till 74. Here is a diagram for that one. See what color the strain relief is on the control module.
Mine is blue. Its not the original engines or trans. I bought it this way. The one thing on these pics is that I have a blue wire on my distributor not purple. Everything else is correct.
Blue module introduced in 1976, original Ford part number: D6AZ-12A199-A which was replaced in 1978 by D8VZ-12A199-A, in 1979 by D9VZ-12A199-A and fairly recently by 1U2Z-12A199-AA
While searching for a good pic, I ran across one with blue instead of purple and one with a red replacing the orange so I don't doubt you. I'd follow the pinouts on connecting plugs. May be an aftermarket distributor thing.
Thanks y'all! This helped me out so much. I think I lost some hair over trying to figure out what was wrong. Everyone here has helped in some way or an other. Again thanks a million!
