wasger fluid
Old Apr 6, 2012 | 02:58 PM
1997fordf350's Avatar
1997fordf350
wasger fluid
my windshield washer pump is not working and the pump isnt bad but theres a clicking noise coming from the right side of the cab inside.thanks
Old Apr 6, 2012 | 03:04 PM
Intimnasc's Avatar
Intimnasc
Well first I have to as how do you know the pump isn't bad? Second there is a relay and I am not positive but I believe it is on the right side that turns the pump on and off. However usually if it is clicking the relay is engaging.
Old Apr 6, 2012 | 09:08 PM
Encho's Avatar
Encho
The Southernmost Mod
Check if the hose didn't broke, that's what happened to me, water wasn't reaching the nozzles. If that isn't the cause you probably have plugged nozzles, mine were nasty when i made them functional some weeks ago.
Old Apr 7, 2012 | 01:24 AM
Midnite1987's Avatar
Midnite1987
So you hear the pump run then you push the button?
The clicking you hear is normal, just the relay turning on/off when you push the button. Now if it's erattic clicking then possibly your issue is in the button. If I puts mine too hard it just clicks rapidly snd nothing happens.
Old Apr 7, 2012 | 01:49 AM
khadma's Avatar
khadma
Carpenter Local 745
Replaced my nozzles and hoses a few years ago.
Make sure that the pump is actually working first before anything else.
The hoses/tubing gets brittle and may be actually leaking in the cowl area.
It is a time consuming job to replace the tubing, so make sure the
pump is moving the fluid.
gmammakn
Mar 23, 2017 09:38 PM
hennecy
Nov 22, 2011 08:30 AM
Chad Winship
1978 - 1996 Big Bronco
Mar 3, 2009 09:01 AM
frdsforme
Jun 22, 2005 03:12 PM
Matt Nalley
Feb 17, 2003 06:39 PM
