Windshield washer stopped sprayin
Old Jun 8, 2005 | 05:19 PM
frdsforme's Avatar
frdsforme
Any solutions as to why my windshield washer stopped spraying? I hear the "noise" as if its going to spray and a click(like a relay) coming from the passenger side underneath the dash but no water sprays out?
Tks for any advice.
1995 Ford 4.9L in line 6, 4x4, 165 000 kms
Old Jun 8, 2005 | 06:35 PM
924x2150's Avatar
924x2150
Park in a dry spot, hold the washer button for 10 seconds and then look under the truck to see if any washer fluid has dripped down, if it is leaking to the ground, the pump is OK, and the hoses are broken. If you can't find a leak then the pump in the washer reservoir may be shot, or the filter/hose is clooged.
I assume the wipers are cycling, that is probably where the noises are coming from, the wipers are controlled by a relay under the dash( maybe under the dash, not sure)
If the pump is bad they cost about 25 bucks at your local shop, If you pull the reservoir out of the truck you can see the pump, otherwise it is impossible to check while the reservoir is in the truck.
Old Jun 8, 2005 | 06:51 PM
turboguy's Avatar
turboguy
mine stopped working... Just took a needle and jammed it down the sprayer part while I had my girlfriend hold the button. They clog up really easy.
Old Jun 8, 2005 | 10:25 PM
skyfox10's Avatar
skyfox10
i'm sure you checked the fluid, but when i tried to use mine, two days after i filled it, it didn't work, but i could hear the pump. turns out the hose poped off and i lost all my fluid.
so if you haven't you might recheck it.
Old Jun 9, 2005 | 04:22 AM
TexasGuy001's Avatar
TexasGuy001
Sounds like the hoses are clogged if the pump is pumping. It could be that the hose came off too. Mine has been doing that occassionally for years. I just put a small hose clamp on it and snugged it up. If you do that don't tighten it up very tight or the tank will crack. I am having a similar same problem. I have replaced the pump motor. It worked for a little while, but now nothing again. The wipers cycle and the relay clicks. The pump is not pumping. Does something else control the pump? I was thinking about putting a new connector on the wiring. I'll probably have to go to Ford for that. I cant figure it out. I have used a multimeter, and it looks like everything is working right. I guess its just not making good connection. I even tried cleaning the connector with Berryman's electronic parts cleaner. I'm at a loss as to what to do.
Old Jun 13, 2005 | 06:56 AM
TexasGuy001
Does anybody know if there is something other than the relay on the passenger side that controls the washer motor?
Old Jun 22, 2005 | 03:12 PM
skyfox10's Avatar
skyfox10
TexasGuy001, you might try running direct voltage from the batter to the pump just to make sure it's still working
Done_Deal
Jan 31, 2018 02:53 PM
cornstar6207
Mar 15, 2014 09:19 AM
CapitanRon
Dec 25, 2013 02:18 PM
Simplex2
Aerostar
Mar 7, 2004 06:50 PM
Boylost1
Aug 15, 2002 07:46 AM
