Fuel Pump Relay Problems
Old Feb 16, 2003 | 07:37 PM
Matt Nalley's Avatar
Matt Nalley
Having problems with my fuel pump. I believe it's the relay because the pump works sometimes and doesn't others. When I disconnected the relay and reconnected it the pump works correctly. I'm puzzled!!!! Can anyone help?
Thanks, Matt
Old Feb 17, 2003 | 03:57 PM
I am Danll's Avatar
I am Danll
Question Fuel Pump Relay Problems
Matt is it stiil giving you trouble? could be the pump giving out too. what year ? what vehicle? do u have a hanes manuel to try a cpuople of things. if so do the fuel pump jumper check to the ECC connection several times and see if the pump starts every time
MMC/SW (RET)
Old Feb 17, 2003 | 06:39 PM
Avanti's Avatar
Avanti
Had a problem with my fuel pump on my 89 Bronco II. Work some time than not. Sometime it would buzz & sometime the pump would not cut off. Turned out to be a broken wire in side of the EEC relay that controls the EEC & fuel pump relay. Tap it & it would work . I used & Ohm meter to figure out the relay had a broken/loose wire on the inside. I would pull each relay & check them out
Beau109
Oct 26, 2015 07:53 AM
Ed_B1
1978 - 1996 Big Bronco
15
Jul 14, 2011 06:39 PM
deanna197
May 28, 2011 08:21 AM
PJ68F250
Jan 24, 2011 12:23 PM
Old Ford Lover
Sep 8, 2009 05:43 PM
