Washer fluid pump? Wiring
Thanks everyone who looked
Hey all. Tried searching for washer pump, fluid pump, etc with no luck so i apologize if this is a duplicate post.
I have a 1993 XLT with the 351. The washer fluid pump seemed a little flaky/intermittent on me a couple times this summer, but of course I wasn't smart enough to dig into it then.
Today I find myself in New England in a snow storm with lots of mud and yuck and no washer fluid. When I push the end on the multi-function switch I can hear a click almost like a relay contacting, from somewhere behind the glove box.
As far as I know the only relays are in the engind compartment of main fuse panel, all on driver side.
Any ideas what i could look at? In the snow? LOL
Can anyone tell me, off hand , where the ground connection on that pump is? Is there another relay I can check up behind that glove box?
Any thoughts much appreciated!
EDIT: I am not ignoring the obvious that the washer pump itself is mechanically dead. I guess I am assuming that any failure wouldn't be as sudden and catatrophic, correct me if I am wrong.
Edit Edit: Nevermind... guy here at work reminded me of the obvious... I took a spare brake lamp, soldered some scrap wires on, jammed them in the contacts on the pump leads... press the button and light comes on. Bad pump. Which I don't have the time or energy to change tonight in the snow LOL
To answer your question about the errant relay, yes the intermittent relay IS up behind the glovebox. It takes it's timing from the multi-function stalk and based upon the voltage it gets from the where the dial on the stalk is set, it changes it's intermittent timing. These relays are pricey but very reliable as long as they stay DRY. (Yes there are hermetically sealed versions but I don't think Ford could even bear to listen when they had to quote a price on such a unit). The "dry location" versions are expensive enough to warrant leaving them in the wiring harness INSIDE the cabin.
Greystreak, thanks for the info on that relay. I'll keep that location in mind, and apparently REALLY hope I never have to replace it.
NDL
1983 - 2012 Ranger & B-Series
04-20-2016 07:59 PM
rpdjim1
12-06-2015 03:00 AM
White Mountain Goat
08-03-2014 04:51 PM
mweaver644
01-25-2014 11:20 PM
9explorer8
09-08-2010 03:09 PM
