My steering shaft...
This first photo is through the wheel well. Notice the ujoint by the gearbox... This removed all play from the shaft while allowing for flexibility.
This next photo is a top view; you can see the ujoint yoke has the female splines allowing it to simply slide onto the existing spline shaft out of the gearbox (the first photo shows the bolt which prevents this from inadvertently sliding off the splines-this would be a bad thing it it occured while driving). Towards the top of the photo is the telescope which is also nessessary to accomodate the flexing between the cab and frame; this flexing slightly changes the distance between the steering column and the gearbox. Without the telescope you could really mess your stuff up.
This is the back part of the shaft where it connects to the steering column. The back half was not really modified other than the replacement of the ujoint.
When I got this truck there was an incredible amount of play in the steering primarily due to the coupler. This resolved most of the play although between a shot tie rod end and the power assist control valve there is a bit more I am hoping to eliminate this weekend. I am looking at installing a power steering gearbox which means I will have to get it shortened a bit to accomodate this.
The thing I like the most is the simplicity of the shaft... The only thing which can wear out are the joints and since they are spicers as long a I grease the occassionally this wont happen; if it does any parts store carries the replacements. This shaft is also very strong. I doubt I will ever do anything which will even begin to strain it.
Any reputable driveline shop can likely fabricate something like this for you. Mine cost about $250 out the door but that included the price of the yoke, both ujoints and the telescope which was upwards of $150 of the cost; I should mention these are premium parts. Cheaper ujoints can be used but you get what you pay for.
Anyways we get lots of posts about problems; I thought I would post about a solution. Feedback and questions are welcome.
I am still running manifolds so I cant say whether there would be clearance problems or not but it seems there would be no more issues than with the original shaft. Most of the added bulk is down by the power steering pump and clearance there doesnt seem to be a problem either although a power assist line ever so slightly graces its presence; I am sure I could adjust this but its coming out this weekend.
I havent seen one but my analysis of the aftermarket shafts was they cost more, would still need to be cut to fit, and did not seem as strong as this setup. Also if there were any issues with the fit of this, the machine shop offered to correct them as I paid for it... Nothing like good local service.
One of the things I have been really conscience of is buying proprietary components. I can not be certain if the aftermarket shafts present this issue.
I just didn't like the idea of the extra weight on that plastic bearing retainer with the small bearing. It's a little under engineered to begin with. His was worn out anyways so I just went ahead and upgraded it so there would never be a issue with it ever again.
Does anyone know any part numbers for this slip yoke?
Thanks
