steering column question
Old Mar 21, 2010 | 08:38 AM
hartski's Avatar
hartski
Can anybody tell me where I can get a breakdown for a 72 F-100 column?
I need to know how to remove the rag joint on the steering shaft. The problem I'm having is since I've replaced the power steering box I'm having line-up problems between the shaft & the box. I suspect the power steering was a retro fit , hence the poor line-up.
It looks as though the rag joint is part of a short shaft that is held to the steering shaft with a pair of set screws. If I can get the short shaft out then I'll be able to order a replacement shaft and u-joint from Borgeson.
Any help or advice would be apprecdiated.
Hartski
Old Mar 21, 2010 | 11:26 AM
starmilt's Avatar
starmilt
Are you trying to convert to power steering with your original column, or what parts are you using, everything should be a bolt up and go here.
Old Mar 21, 2010 | 12:29 PM
hartski's Avatar
hartski
Yeah, I'm trying to convert to power steering with my original column. After I bolted everything up I noticed the alignment is off approximately 1/2".
However, after doing a search on this site I found a step by step chronicle of such a conversion, complete with color photos. Superbly done I might add. Anyway, it looks like I can remove the rag joint form the steering shaft to revael the splines underneath. After that it'll just be a question of ordering the right U-joint. It should be pretty striaghtforward.
Hartski
