p1316 no start
Old Apr 16, 2012 | 06:34 PM
marc13's Avatar
marc13
im located between akron and cleveland ohio
How is the duty cycle tested?
Old Apr 16, 2012 | 06:41 PM
BigAlsPSD's Avatar
BigAlsPSD
With a scanner capable of reading live data from the PCM.
Old Apr 16, 2012 | 06:48 PM
marc13's Avatar
marc13
Oh gotcha. Yea all i have is an edge evolution programmer and a basic mac tools scanner. Neither read much without the truck actually running
Old Apr 17, 2012 | 06:53 AM
DieselDowdy's Avatar
DieselDowdy
I just went threw this try not to pull ur hair out .....I had the same problem I was going nuts .....u need to have the truck scanned and have a Koeo self test performed.....that's needs to happen first before anything is done ......this test will throw codes related to the problem . Basically the code will relate to the problem part with in the system .....the system includes the IDM, wiring to the under valve cover harness connector ,then threw the connector to the each injector .....so every code that is trown is related to a specific piece with in the system ?...post the codes so we can help you this is gonna be a brain tickler don't give up no matter what.
Old Apr 17, 2012 | 07:03 AM
marc13's Avatar
marc13
Sorry for my ignorance but what is a koeo test and where can i get one?
Old Apr 17, 2012 | 07:10 AM
DieselDowdy
Key on engine off ..... Self test the test can only be done by a higher end scanner that surports enhanced obd 2 functions such as a snap on soulus or modis finding someone in ur area that has on will be the hardest part of diagnoseing the problem. U might be able to find some one on FTE that has one in ur area I have one but I'm in Florida
Old Apr 18, 2012 | 03:57 PM
marc13's Avatar
marc13
is this type of scanning something a dealer can do? I cant find anyone that has the nice of a scanner. I have aaa so towing is free wherever i take it. Maybe if tgey scan it i can tow it back home and repair myself?
Old Apr 18, 2012 | 04:03 PM
Tugly's Avatar
Tugly
Have a look to see if this will help [LINK]
Old Apr 25, 2012 | 06:16 AM
marc13's Avatar
marc13
well since I havent found a scanner yet Im going to swap a few parts with a 2000 e250. Maybe i can figure it out that way if thats the issue.
Old Apr 25, 2012 | 12:51 PM
DavidE's Avatar
DavidE
Edge Evo Reads codes
Marc my Edge Evo will read the codes. Look on Egdes website to download your manual to see how.
Old Apr 25, 2012 | 01:45 PM
marc13's Avatar
marc13
The code i got was p1316 thats an idm code. But you need an advanced scanner to read the codes stored in the idm
Old Apr 25, 2012 | 11:47 PM
fixnair's Avatar
fixnair
I too struggled with a P1316 IDM codes stored. I fought it for three or four years. The truck ran fine but the check engine light was always on. Last year California started requiring smog tests and now I had to get rid of the CEL. Took it to an independant shop that had a lot of experience with Fords plus they had the Ford scanning tool. They found the wiring harness under the hood was frayed through in a couple of places. replaced that and now all is well.
Old May 6, 2012 | 05:42 PM
  #28
marc13's Avatar
marc13
Well i havent had much time to work on truck but i replaced the cam position sensor for sh%$s and giggles and fully charged the batteries....nothing changed though. Cranks very strong tach moves and smoke comes from tailpipe. Tomorrow after work im towing it to dealership to have them diagnose it. I'll post what they tell me. Thanks everyone for the help though.
Old May 17, 2012 | 06:41 AM
  #29
marc13's Avatar
marc13
Well I broke down and had AAA tow it to a local reputable Diesel shop (R & R Engine in Akron, OH) and It ended up being my IDM. They showed me my old IDM and it had a pile of salt and corrosion on it about 4 inches in diameter. The tech used a pocket knife to move it and sure enough there were tiny holes eaten through all over it. $500 out of my pocket but well worth it to me. Its been so long since I drove it that I forgot al the other things wrong with it! My caliper and hose need changed badly and its leaking tranny fluid like crazy. I thought it was 2 bolts on the pan that need tapped out but after looking at it last night it seems to be running down the filler tube possibly. All I know for sure is that I'll be posting more threads on here for months to come until I get this machine in top running condition. Once again I appreciate all the help on here from everyone!
Old May 17, 2012 | 01:19 PM
  #30
BigAlsPSD's Avatar
BigAlsPSD
Glad you got it figured out, IDM's are IMO rare to fail, but moisture and corrosion will destroy things, since you are considering doing your own maintenance consider this...I realize it is more than the $500 that you had to spend but with the group on this site, we could have led you in the directions needed with good information.
Riffraff Diesel: AutoEnginuity Total Ford Enhanced Bundle This tool will allow for those full diagnostics that you would need.
Riffraff Diesel: Alliant OEM 7.3L Injector Driver Module IDM
tom from mass
Aug 27, 2016 06:19 AM
super444
May 5, 2014 01:29 PM
01FordExc
Dec 3, 2011 06:49 PM
ford-diesel-91
Dec 5, 2010 07:27 AM
renan
Oct 21, 2010 03:25 PM
