'97 7.3L no start
Old Aug 24, 2016 | 08:36 PM
tom from mass's Avatar
tom from mass
'97 7.3L no start
getting tired of getting towed. 188,000 mileage, Within past 3 weeks 3 tows.broken brake line over rear diff. $300, Ford Dealer. Dead starter $280. Replaced GPR $196. It would start after slow 10 count after "wait to start" light went out yet still cranked for 2 seconds before start. ran great at highway speed. yesterday would not start. Retired, can't afford to replace. I always thought this engine would never crap out. Are there any codes that would positively identify the problem (it's back at the dealer for their $100/hr rate) I did treework for $25/hr for 35 yrs. any ideas anyone?
Old Aug 24, 2016 | 09:15 PM
Diesel_Brad's Avatar
Diesel_Brad
There could be SEVERAL causes for a no start and have NO CODES
DO you have oil in the truck? Low oil will not allow the injectors to fire.
Do you have fuel in the truck?
Do you have fuel pressure?
Fuse #22 under the hood, is it blown?
Next you would want to put a scanner on to read values and parameters
Old Aug 24, 2016 | 09:29 PM
wtroger's Avatar
wtroger
There is a connector on each valve cover gasket That supplies power to the glow plugs and power to the injectors that connector and related wiring unde the VC is known to melt and cause issues. Last one I worked on only has one glow plug working. An intermittent miss on 2 cylinders. Replaced the glow plugs valve cover gaskets and a couple pieces of under VC wiring and we where good to go.
Old Aug 27, 2016 | 06:19 AM
tom from mass
Good news! The Ford mechanics diagnosed the problem and determined that a faulty alarm was preventing fuel flow. Removed alarm. Truck now starts immediately when "wait to start" light goes out. only $98. charge
GlennSwett
144
Mar 13, 2014 11:08 AM
rowdyredneck
13
Aug 22, 2013 08:59 PM
FoxNotch
22
Jan 15, 2013 10:07 PM
ford-diesel-91
Dec 5, 2010 07:27 AM
F350Bandit
Oct 22, 2007 02:10 PM
